JC Refrigeration 12 volt compressor cooling unit
rhagfo
Well our cooling unit has failed, pretty sure no cooling on gas or electric. Noticed some dreaded yellow powder and a slight smell of ammonia.
So now looking at the JC Refrigeration 12 volt compressor cooling unit. I have the room for it, and it seems like it should work better then the absorption unit.
Are there any members that have real world experience with one of there units?
Our refer is a Dometic RM2862, the replacement unit runs $785, install is $0.00 as I will do myself.
We replaced the cooling unit 8/3/2018, so got just over four years out of a new unit. A new absorption unit runs $740, and a rebuilt is $450. That puts the cost on par with absorption unit.
We full Time and mostly park host, so almost always have power, we have two Interstate SRM-27 batteries in parallel, if without power.
15 REPLIES 15
kincade
OP, wondering if you have any updated info on usage? How many Amp Hours do you estimate the unit uses?
rhagfo
RLS7201 wrote:
Your SRM 27 deep cycle batteries are NOT true deep cycle batteries but are RV/Marine batteries. They are compromise batteries. On a cold night they would probably NOT run the furnace and the refrigerator all night. The furnace blower is a high amp draw item.
Richard
Furnace alone T-stat at 65, outside low 30’s ran all night, on a single five year old SRM 27. Now run two in parallel, I didn’t see an issue. That was for a nine day period, charged during the day.
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Housted
rhagfo wrote:
Well unit installed and within 2 hours refer at 38 and freezer at 5 degrees. Nora bad DIY project, hardest part getting unit out of the box, very well packaged.
X2 I also had difficulty getting the unit out of the box !!:E
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
rhagfo
goducks10
My bad, I didn't see the under 10 cu.ft shipping cost.
rhagfo
goducks10 wrote:
$500 to ship puts you at $1285.00
For that much money I'd buy a 10 cu.ft 12V compressor fridge. I've had my GE 9.8 cu.ft 12V compressor fridge for 3 season and it's been flawless. It's a little power hungry but I have solar and a gen when needed so it works out fine.
The added room going form 8 cu.ft to 10 cu.ft is well worth the swap out. All 12V 10 cu.ft fridges are pretty much plug n play.
Not sure where you got $500 for shipping, it was $95, I also got a $150 discount as my four year old adsorption unit failed.
We shall soon see how well it works.
goducks10
SoonDockin
Last fall I drove to Shipshewana and had them swap my norcold NX8. It took them 1.5 hrs from start to finish. I rooled in at 8am and was on the road for home by 10:00. No regrets. They did a stellar job and I could not see any sign they had been in my camper. They did the swap on the floor of my unit.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
rhagfo
I would think there would be a few more members that have made the move to the 12 volt compressor system.
rhagfo
We don’t boondock, only need to deal with the occasional power outage we have two Interstate SRM 27 deep cycle batteries in parallel, that should run the refer over night and the furnace.
JBarca
Nomad II
Nomad II
johnhicks wrote:
https://www.rvtravel.com/12-volt-refrigerator-rvt-1065/
Good link, Yes, understand what "your" needs and power requirements are when boondocking, then choose what fits for you.
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
Housted
I am on my second JC conversion (two different rvs) I will never go back to the old way.:C Install is easy if you read and understand the directions.:B Our present refer is a 4 door Dometic and has two compressors. One for the fridge and one for the freezer a much better arrangement for a large fridge. I do have 1000 watts of solar and a 400 AH lithium battery.
All in all I say got for it you will never look back!!:B
johnhicks
-jbh-
