โSep-20-2015 03:37 PM
โSep-22-2015 07:12 PM
pkunk wrote:Fisherman wrote:
Probably no longer on the market as flashing red lights of any type are reserved for emergency vehicles.
Alot of the newer vehicles the 3rd brake light flashes a number of times before going solid red. Superbright LEDs has flashing LEDs, but if behind a red lens you should buy a red LED
โSep-22-2015 11:01 AM
buc1980 wrote:
What kind of LED bulb you use to replace the incandescent bulb(12v).I see a lot of them on the internet but I don't know how bright they are.Somebody can come with an answer.
โSep-21-2015 08:03 PM
โSep-21-2015 04:58 PM
RVJimofOregon wrote:
About 10 years or so ago I got stop light bulbs that when you stepped on the brake they flashed slow and then faster until full power. It was a plug in (had a board with them). I never again have found them. When I sold the rig I took them out and gave to a friend and he used them for years with no trouble. The best stop lights that I have ever seen. Must of had a least twice the output of a normal bulb.
I know this is not the answer to your question but just a area to look into and maybe you can find them and if so please share the info.
Flaguy
โSep-21-2015 11:29 AM
ChooChooMan74 wrote:
I would change them out to LED fixtures. The manufacturer of the taillights on my roo also made an LED version. I basically swapped out the guts.
โSep-20-2015 05:07 PM
โSep-20-2015 04:43 PM
โSep-20-2015 04:12 PM
โSep-20-2015 03:45 PM
