LED bulb for FW stop light
buc1980
What kind of LED bulb you use to replace the incandescent bulb(12v).I see a lot of them on the internet but I don't know how bright they are.Somebody can come with an answer.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
9 REPLIES 9
Fisherman
pkunk wrote:
Fisherman wrote:
Probably no longer on the market as flashing red lights of any type are reserved for emergency vehicles.
Alot of the newer vehicles the 3rd brake light flashes a number of times before going solid red. Superbright LEDs has flashing LEDs, but if behind a red lens you should buy a red LED
Not that I don't pay attention to brakelights, haven't seen any flashing CHMSL's up here.
4x4van
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
pkunk
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Fisherman
RVJimofOregon wrote:
About 10 years or so ago I got stop light bulbs that when you stepped on the brake they flashed slow and then faster until full power. It was a plug in (had a board with them). I never again have found them. When I sold the rig I took them out and gave to a friend and he used them for years with no trouble. The best stop lights that I have ever seen. Must of had a least twice the output of a normal bulb.
I know this is not the answer to your question but just a area to look into and maybe you can find them and if so please share the info.
Flaguy
austex
ChooChooMan74 wrote:
I would change them out to LED fixtures. The manufacturer of the taillights on my roo also made an LED version. I basically swapped out the guts.
^^ This. I replaced the incandescent back-up bulbs on my truck with LED "bulbs" - worse lighting in reverse now, except in one very narrow area, due to lens/bulb mismatch.
Tom & Jessie
Central Texas
MVPRV(RIP) Coast 26LRBS TT
ChooChooMan74
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
filthy_beast
There was an article in a Trailer Life that pointed out the issue with just replacing the bulb. The lense that is designed for incandescent bulbs kind of lack when the bulb is replaced with LED bulbs. You might want to consider replacing the entire light fixtures.
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
You cannot make things idiot proof, you can only make them idiot resistant.
RVJimofOregon
Flaguy
Jim & Joyce
Central Oregon Coast
26 foot 2004 Komfort travel trailer
2014 Platinum Tundra pickup
Treat the earth well, It was not given to you by your parents,โ€œIt was loaned to you by your childrenโ€
Indian proverb
agesilaus
Usually you will see a lumen output listed. A 75W incandescent is about 1100 lumens IIRC.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
