Jul-21-2020 07:51 PM
Aug-15-2022 02:06 AM
colliehauler wrote:
Hopefully the Forest River will be better engineered.
Aug-14-2022 04:38 AM
longbedbob wrote:
Instead of adding a second roof mounted AC to our fifth wheel, I'm investigating a mini split unit instead. Weight, but most importantly, power considerations are my motivations.
Aug-11-2020 05:11 AM
Aug-11-2020 12:54 AM
Aug-10-2020 11:42 AM
hottub wrote:Alpha Leisure use to have basement mounted units. My understanding is they didn't work well and failed often. Hopefully the Forest River will be better engineered.
check out the new Forest River River Ranch fifth wheels coming out in Oct.
ac units mounted in basement
Aug-03-2020 07:07 AM
Jul-27-2020 03:21 AM
Jul-26-2020 08:12 PM
Jul-23-2020 03:47 AM
Jul-22-2020 10:37 AM
Jul-22-2020 10:34 AM
Jul-22-2020 10:18 AM
Jul-22-2020 07:22 AM
LanceRKeys wrote:
I would be concerned about the added heat load to the camper. Along with leaving the access door open, you may need a fan to force some air movement. I would also caution you on draining the condensate to the sink drain. That is going to add quite a bit of water to your grey water tank. If you camp in a hot humid place without full hookups, that could be a problem.
You may be onto something, keep us updated as to what you find.
Jul-22-2020 03:35 AM
