โFeb-08-2022 05:11 PM
โFeb-11-2022 09:19 AM
Goostoff wrote:fmeili1 wrote:
Hi,
since a couple of weeks, I'm thinking and planning about building my own LiFePO4 battery to replace my two "old" lead acid 100AH AGM group 24 batteries
Frank
Be sure of what you are replacing. lead acid and AGM are not the same. If you have lead acid batteries maybe a simple upgrade to AGM is all you need and keep it simple.
โFeb-11-2022 04:35 AM
fmeili1 wrote:
Hi,
Frank
โFeb-10-2022 06:06 AM
โFeb-09-2022 01:58 PM
fmeili1 wrote:
1st stage: inside fan only
2nd stage: inside fan plus peltier and outside fan
In 1st stage the energy consumption would be very low, just the inside fan. The 70 watt peltier will only be used when 2nd stage will be active.
โFeb-09-2022 05:35 AM
โFeb-09-2022 05:08 AM
โFeb-09-2022 04:35 AM
โFeb-09-2022 02:34 AM
fmeili1 wrote:
Because I need the peltier anyway for cooling, I've decided to use it also for heating and so I don't need additional heat pads.
โFeb-08-2022 08:36 PM
โFeb-08-2022 08:14 PM
โFeb-08-2022 07:56 PM
โFeb-08-2022 06:54 PM
theoldwizard1 wrote:
Moving air does a good job of cooling if it is properly directed. Check out Noctua fans. Very quiet and last a long time
โFeb-08-2022 06:46 PM
โFeb-08-2022 05:45 PM
