Replacement Sink?
Vintage465
So I have 2015 CreekSide 20fq. It has one of the plastic kitchen sink that has the small sink on the right and the larger sink on the left. Has anyone tried to replace those with a stainless steel sink? All the ones I see in the catalogues won't fit the opening. If I could find one that needed a little larger opening, I could hog mine out a little.
Thanks,
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
9 REPLIES 9
Bill_Satellite
I put a SS sink in our RV but it was not a standard RV sink that I replaced. It took a bit of looking but I found one that was the right size at either Home Depot or Lowes. There are a lot of sinks on display and there are others available on-line. We also found a new bathroom sink at a Pacific Sales store. You can check that or similar home goodies stores.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
galtgirl
I want to replace my sink as well. I have a double stainless steel sink that is undercount with solid surface countertop. I'd love to have a single bowl sink. Looked at the link for the custom fabrication and you're right, it's very expensive. Maybe next year?
John and Carol Beckman
USN SKC RET (him) RN (her)
Lola & Ava the French Bulldogs
Sacramento, CA
2015 Heartland Bighorn
2017 Silverado 3500 HD High Country
Vintage465
This is all some massively great info. I am thinking a trip to Lowes is gonna happen. That will get rid of the cheesy sink and the cheap faucet! That will happen soon as I get the new cabinet built to put our kitchen and table goodies in! Glad I'm not the only one who dis-likes these sinks.
Thanks!
V-465
bowebow
Try IKEA also.
2007gmc duramax 2500hd
2014 V CROSS 30VSK
wolfe10
Clicky: http://www.lowes.com/pd_544629-28557-G202721_1z0tog1Z1z0u6h1Z1z0u6mbZ1z0y4g4Z1z1291fZ1z1408j__?produ...
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Tyler0215
Measure the sink opening and go to Lowes, Home depot. If you don't see a sink that size see if they have a special order that will fit.
PHM4LR
I replaced plastic sink with this unit
http://www.lowes.com/pd_544629-28557-G202721_1z0tog1Z1z0u6h1Z1z0u6mbZ1z0y4g4Z1z1291fZ1z1408j__?productId=50114004&pl=1
The hole had to be enlarged front to back in my situation, and we replaced the faucet set with a pull out/spray single handle.
old_guy
can you cut the hole larger?
path1
Thanks,
Same problem here. We have sort of weird size. New sink is on the list but few other things first. I called this place and they make about anything, but they sure charge...one reason why it's on back burner for now. Also plumbing under sink will need stuff also.
https://www.stainlesssupply.com/stainless-kitchen-products/docs/stainless-sinks-custom-undermount.ph...
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
