slide button cover?
Roundtwo-40
I have a small slide in the bedroom that requires a slide locking bar to hold the top against the seal (from factory) there is a sticker next to the slide button warning against movement until the bar is removed but I would like a more idiot-proof way of covering/locking the slide button until the bar is removed..Any ideas?
2013 Jayco Eagle 328RLTS w/15K AC
2013 Ram 2500 CTD CC 4X4
Equalizer 14K,PI PT30C Surge
13 REPLIES 13
mikefos
Roundtwo-40 wrote:
Carlon E98GFCM was my part number you are correct.
Note: I had to remove some of the plastic from the top of the half that attaches to the wall to allow the slide button to fit properly inside the cover (pic).
Happy Camping.
Great, thx for confirming. I will be on the hunt for one locally here.
Mike
Mike and Kim
2012 Jayco Eagle Super Lite 308RETS, TST 507 TPMS
2010 Chevy 2500HD, Duramax/Allison, 2WD, Long Bed, Crew Cab, Duraflaps, AMP Bedstep
Equal-i-zer 1400/14K Hitch
Roundtwo-40
Happy Camping.
mikefos
Roundtwo-40 wrote:
Exterior outlet cover (switch not recepticle) at Menards.
Hi Roundtwo, do you have the Carlon part number? I think it is E98GFCM. We don't have Menard's here, and they want about $10 to ship.
Thx,
Mike
Mike and Kim
Gene_Ginny
I saw a good solution at an open house at our local RV dealer that was common to one brand (which I have forgotten). The slide switch was activated by a key. The key was attached to the slide locking bar. When the bar is in place you can't activate the in/out switch.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Roundtwo-40
mikefos
Roundtwo-40 wrote:
What I did for future reference..
Hey Roundtwo,
Where did you get that? Looks good.
Mike
Mike and Kim
Roundtwo-40
lpxguy
On my previous TT the slidelock had a string with a bright orange tag on it dangling so I'd have to be blind to miss it
2005 GMC Sierra 3500 CC DRW D/A(FOR SALE)
2013 Crusader 335BHS TE(FOR SALE)
falconman
I used a clear plastic bar soap case with a hinged lid I got at Walmart for $1. Remove switch and detach the three wires. Cut hole in case, run wires they hole and reattach to switch. Screw switch with case back onto wall. Fits perfect with my switch, yours may differ.
fcooper
I have a similar problem in that I need to remember to check the driver seat position before moving the slide. I placed a small piece of cardboard (part of a file folder) taped over the switch with the reminder to check driver's seat before moving slide. I have to lift up the reminder to operate the switch.
Fred
Fred & Vicki
St. Augustine, Florida
Roundtwo-40
K Charles wrote:
I leave the slide lock home.
Not an option,I did that once, the top of my slide tips out and had 2" of snow on top of my slide INSIDE the RV as it does not seal against the top (It was a wind driven snow in March).
K_Charles
rexabbot
I put an outdoor outlet metal flip cover with a spring on my main slide.
Like this Clicky
