โOct-10-2015 08:11 PM
โNov-26-2015 11:17 AM
โNov-26-2015 10:03 AM
โOct-21-2015 07:23 PM
myredracer wrote:rjxj wrote:
I installed a Torqlift model A7804 step system on my FW last week. After doing an axle flip I had looked at Lipert and other brands of 4 step units but also read about having to support them. I figured if a 3 step bounces, a 4 step would be even worse so I never bought.
How high is the floor of your trailer above the ground elevation with level ground & level trailer?
There is a wide variation in floor heights in trailers due to different equalizers, springs, over/under slung axles and tire dia. and height of I-beams and the bottom step adjusts from min. 7.5" above grade to +10.5" above grade.
โOct-21-2015 07:37 AM
โOct-21-2015 07:06 AM
93Cobra2771 wrote:
Did you do a weight comparison between the old and new steps?
โOct-20-2015 06:58 AM
grizzzman wrote:
If you dont mind my asking. Did you gain ground clearance under the steps as compaired to the old steps?
โOct-20-2015 06:22 AM
โOct-20-2015 05:13 AM
โOct-11-2015 05:57 AM
edatlanta wrote:
I read on their site that a step can be added or removed easily when needed, but there doesn't seem to be a video to show how it is done.
Do you know how easy this is?
โOct-11-2015 03:52 AM
โOct-10-2015 10:15 PM
