Where does my tv plug in?
skrams
We want to replace the bedroom tv with a flat screen. We took out the drawers to see where it attaches/plugs in. As far as we can tell, there seem to be two wires (power and cable) that run from the tv down, then towards the front of the rv. Is this possible? We can't find a socket anywhere behind or around the tv.
If it's right, any suggestions for hooking up the new tv?
2007 Four Winds Hurricane 34B (Ford Chassis) Bunkhouse
2007 Chevrolet Cobalt LT (5-speed manual)
SMI Stay-In-Play & Blue-Ox Aventa LX
10 REPLIES 10
skrams
Rich, that would make most sense, thanks.
cltkids
Hi Skrams,
I looked into ours to add a DVD player in the back of ours... I am pretty sure there is an outlet mounted behind the TV.
Rich
2017 Newmar Ventana 4310
2007 CR-V w/ Blue Ox Aventa LX/Even Brake
wittmeba
If the power is not using a plug/receptacle you could use the same wires as skipnchar suggested by installing an outlet and use the old wire from the current TV set. You could do the same for the coax with their connector.
NRA Member & supporter of the 2nd amendment - over 5,000,000 strong
Firefoxยฎ 33
Log home images - Updated 05/19/2013
RoyB
If your current TV in the bedroom is running off of 120VAC and has a TV F-Connector plugged into the ANT CONNECTOR then just use that on your new flat screen TV.
My trailer has a regular 120VAC receptacle and a F-Connector receptacle right next to it for my Bedroom TV
If you have a 12VDC TV septup then someone has probably wired it up without using a standard receptacle type wall box...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
hershey
I'm guessing that since you said you can't find the socket, your TV is a 110 volt TV. But it doesn't matter.
I'd suggest making sure the power is off to the proper voltage draw and just clip the wire at the TV and then splice the wires from the new TV to the existing wire. Put the splice in a small electrical box and your good to go. Just make sure your keep the polarity the same.
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
byways
I'm guessing (you shouldn't do this!) that the tv is 12 volt. No reason (except for donn0128's comment) that wires would be run that far for power.
Johno02
Follow the wires. Looks inside a closet or cabinet close by. Best thing on that young a model is to call Thor in Elkhart and ask. Call the service department, they will have a complete set of plans and wiring. I always foud them nice and easy to work with.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
skipnchar
Check the wires for current. If it's 120 volt AC then why not use the same wires? probably would be a good idea to know just where they originate though, so you know which breaker controls them and what else is on that circuit.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
donn0128
Anything is possible in An RV. It all depends on who and when they put the wiring in. All you can do is follow the wires.
