Will it fit thru the door?
ohiopicker
We want to remove the fold-out hide-a-bed sofa from our fifth wheel and replace it with a smaller unit. We know those fold-out's are heavy as all get out, but will they fit thru the door?
I welcome any advice from folks who have done this.
5 REPLIES 5
powderman426
Mine fit through with no problem. I now have a recliner and looking for a second one to match.
BTW. If putting in a recliner, get a wall hugger.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
rav
the sleeper sofa in our TT, the back came off and it was easy to get out, look for a smaller one that the back comes off also. JMHO
also it was screwed to the floor with "L" brackets
SDcampowneroper
The back might lift off, like a lazy boy chair. Ours did.
Johno02
Be sure and tie it together after you get it loose and folded. Otherwise you might be in for a big problem about half-way out the door.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Dr_Quick
Just put sofa in the open/flat position and you should be fine. Stand on edge and it should fit through the door.
Dr Quick
