Feb-02-2014 02:52 PM
Feb-03-2014 02:35 AM
dpark wrote:
I am not looking for the weight police to chime in, I am looking for answers from people with the above truck or a legitimate answer. I am going to pull the trigger on a 2500HD this week (truck is already picked out with deal made) but didn't do it due to just needing to make sure I am within specs.
The truck is a 2014 2500LTZ 4x4 crew cab with a Duramax/Allison combination. GVWR 10000lbs. The truck specs are 2706# payload, 6200# rear axle, 5200# front axle 15800# fifth wheel towing, 24500# GCVWR
My fifth wheel that I currently own and will be pulling with it is a 2014 Keystone Cougar High Country 315RES. Specs are 8563 empty with 2437 carrying capacity...leading to 11000# Gross rating. I know this is fine, but the pin weight is listed at 1600# and when I weighted it on our truck scales it was closer to 1800# loaded.
Is anyone towing something similar to this and do you feel I am within specs to be legal?
Feb-02-2014 11:47 PM
Feb-02-2014 08:07 PM
Feb-02-2014 05:22 PM
Feb-02-2014 05:14 PM
Feb-02-2014 05:06 PM
Feb-02-2014 04:38 PM
Feb-02-2014 04:31 PM
Feb-02-2014 04:30 PM
Feb-02-2014 04:22 PM
dpark wrote:My truck has the same payload as that one you are looking at.
Feb-02-2014 04:19 PM
shadoow wrote:
you mentioned a truck spec of 2706# for payload. Is that based on the actual wt. of the truck or somewhere else? Your room for pin wt. would be the difference between the truck GVWR and the actual wt. of the truck loaded as if you were going camping (i.e. you, wife, dog, kid/s, hitch, tools, full fuel tank, etc, etc.). Just guess-timating from when i had a 2009 GMC 2500HD D/A (GVWR of 9200#) i would say you should be ok. My actual truck wt. loaded up for camping came to a little less that 7200# leaving me 2000# for pin wt.
mguay wrote:
You didn't say if it was a Gasser or a D/A? If it is the 6.0 Gasser...make sure it has the 4.10 rear end! I had an 09 6.0 with the 3.73 rear and my current 5er and had a hard time getting 8 mpg while towing!
Feb-02-2014 04:14 PM
mdamerell wrote:
If you are asking the question you must know in the back of your mind you'd be better off with the 3500. For the price difference why not get the 3500 and not worry about it?
Either way, I hope you enjoy your new truck 🙂
Feb-02-2014 04:11 PM
Feb-02-2014 04:10 PM
