azjeffh wrote:
Thats_Ok wrote:
In a nutshell:
After backing under the hitch and watching the handle drop or jaw-lock.
Pull or "tug" forward slightly to make sure the truck doesn't come away from the hitch before raising the front landing legs.
Just don't drag the trailer with the feet down.
I believe you should raise the legs until they're just slightly off the ground before attempting to pull it. Wheels chocked is best but electric brake may work ok also.
Azjeffh, I disagree with the raise the legs, once you put all the pin weight on the hitch, if high hitched it will be very difficult to pull the pin over the hitch.
I have wheels chocked back in, with the pin box about an inch low to the hitch. As soon as the jaws shut do two quick tugs forward.
To those the go oh the strain on the LG, chocked wheels, and there is some play in the LG anyway.
