โNov-20-2019 07:07 PM
โNov-23-2019 12:54 PM
valhalla360 wrote:
Your premise is incorrect. Most use a single starting battery (sometimes relabeled as a combination battery but really just a starting battery if you open it up and look at the construction).
If you don't camp off grid, it's a perfectly good solution. Jacks & slides will generally pull less than 100amps for less than 30seconds and a starting battery does just fine doing that.
Only reason to consider Gel or AMG is if you are going to roll your RV. The big advantage to them is they don't leak out the acid if you put them on their side or upside down (planes, boats, jeeps can gain advantage as they often spend time substantially off level). They offer no real advantage in an RV.
โNov-23-2019 10:06 AM
โNov-23-2019 08:34 AM
โNov-21-2019 04:24 PM
โNov-21-2019 03:25 PM
โNov-21-2019 01:42 PM
โNov-21-2019 01:01 PM
โNov-21-2019 12:39 PM
โNov-21-2019 12:08 PM
opnspaces wrote:Marine batteries cost as much or more than golf cart batteries. Ask me, I have a boat as well. Using starting batteries for house batteries will work, but they wont last very long. I guess if someone is going to haul their camper to an rv park and never move it, it doesn't really matter what kind of battery they have. I had an electric golf cart that all the batteries died. I had an assortment of starting and marine batteries laying around, so I configured them so they would run the golf cart. They did the job, the golf cart ran, but they would only go so far before they would be depleted, and after a while, they didn't seem to charge as good. Eventually, a new set of golf cart batteries were purchased, and all was good again. I do believe anyone with any knowledge of batteries will confirm the use of golf cart batteries to be the best choice if you ever plan on boondocking, or camping without hookups at all. If you never plan on moving the rv, go with your plan, and get the lawn mower battery.gmg wrote:
Most RVs seem to have lead acid deep cycle marine batteries. However Iโm just thinking that most but not all RVers rarely camp without shore power. The most instantaneous power demand is when running out slides or deploying jacks. So it seems to me that a standard or combination starting battery makes more sense than the deep cycle marine battery. One more question I have: Iโm wondering if the higher cost for agm batteries is worth the money. The plus side to me is not having to keep up with the electrolyte levels. I would be interested in what others think about this or have experienced.
I disagree with some of the OP's assumptions, but overall I agree with the basic thought.
While I know we talk about switching to deep cycle batteries; I think it's important to keep in mind that the forum crowd is a very small microcosm of the overall RV community. So while it's easy to equate what a small group of people loudly proclaim to be best with what the general population believes, it just isn't really the reality of the beliefs of the general RV owner. If you think about it, of the multi million subscribers here on RV.net, probably no more than 1000 regular posters (I think 1000 is very generous by the way) are singing the virtues of deep cycle batteries.
I would bet that the majority of the multiple millions of RV owners are driving or pulling an RV with a standard marine or automotive starter battery because they are recognizable and readily availibe.
All that being said, I one hundred percent agree with your post that if a RVer typically has electric hookups all they need is a cheap automotive starter or marine battery. In fact I will even go one step further and suggest that for a trailer (5th wheel, travel trailer, popup etc) owner who camps with hookups; All they really need is a cheap thirty dollar 12 volt lawn and garden battery from Walmart that does no more than run the slides and activate the emergency breakaway system if needed.
โNov-21-2019 08:17 AM
โNov-21-2019 08:06 AM
โNov-21-2019 07:08 AM
โNov-21-2019 07:00 AM
โNov-21-2019 06:17 AM
