Apr-29-2017 11:47 AM
Apr-30-2017 09:14 AM
Apr-30-2017 08:48 AM
Apr-30-2017 07:54 AM
I used 2" lift blocks on both my toy haulers and that fixed my nose high situation, even though other than looks can't tell it made any difference. Not had any issues though some poo-poo the thought of doing that.
Apr-30-2017 07:30 AM
Apr-30-2017 06:54 AM
davisenvy wrote:
I don't think the correct track is enough, but would definitely help. Is there such a thing as air bags I can put under the trailer suspension like you can put on a truck. That would be perfect!. Air them up for a level tow then air down so I can use the out side kitchen without a ladder.
Apr-30-2017 06:46 AM
Apr-30-2017 06:27 AM
wing_zealot wrote:
Weigh the two axles individually and see if what the dealer says is true. It seems to me it's worth the $20 bucks to find out before you spend hundreds to fix a maybe problem.
Apr-30-2017 06:13 AM
Wild Card wrote:
If its 8" differance from front to rear you are only 4" out of level. Correct track is 2" and if you can go to 235/85 tires is another inch or better and call it good.
Apr-30-2017 06:06 AM
Apr-30-2017 04:28 AM
Apr-29-2017 09:47 PM
Apr-29-2017 08:59 PM
Apr-29-2017 07:16 PM
Apr-29-2017 05:56 PM
davisenvy wrote:
The leaf springs are already on top of the axles. The dexter axle flip kit wouldn't do me any good. The only options I have found are bigger wheels/tires, lippert correct track and/or subframe lift.
Apr-29-2017 05:39 PM
