Can I walk on top of slide?
timberloft
I am in the process of replacing my slide toppers and did the bedroom slide using ladders. I have a friend lined up to help me with the dining/living slide in the next few days. I am sure that we can do it using ladders, but it looks like it might be easier if one of us was on top of the slide. Can I stand on top of the slide unit without causing damage to the slide? Thanks for your input.
Walter & Genie
Coton de Tulear (Chloe)
2003 Montana 2955RL
2014 Flagstaff MicroLite 21FBRS
19 REPLIES 19
ependydad
I know I was reading of one manufacturer (Wildcat, maybe) that said you could walk on theirs. I don't think I could do it, though.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
cdlaine
Yes, you can walk on yours...please don't walk on mine.
Charles
2003 2500HD, 8.1L,CC,4.10,2WD,Allison
Standard bed
Ride-rite air bags
Prodigy
Husky 16K sliding
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
I'll want the Frim Fram sauce with the Ausen Fey with
Chafafa on the side.... Nat
Old-Biscuit
I wouldn't do it! Here are the reasons why.......
MFL wrote:
You can seat up to 6 people on that slide, due to the weight being supported from below. I don't believe there is much support in the slide roof.
TakingThe5th wrote:
unlike the main roof, there is no truss support structure in my slide roofs.
Dtaylor wrote:
There is support along the outer edges along the walls. As you near the center and along the coach itself, the only support available is whatever type header the manufacture has put in.
ScottG wrote:
No way I would walk on it. If you were to crack the "rigid foam insulation" (styrofoam) it will forever sag.
ALL good reasons NOT to do it.
No good reasons why to do it
ScottG
Randu
Really depends on camper construction and it might also vary depending on floor plan. I had 2 Fleetwood Terry products that no way unless you wanted a new skylight. Walked all over my Travel Supreme, Kountry Star, and Mobile Suites without issue.
If I were to try----
Very carefully put weight at edges and slowly work towards center being aware of any sounds like cracking or flex in the roof.
Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
jaycocamper6230
tvman44 wrote:
I don't see why you could not do the job from ladders. ๐Ÿ™‚
That's what I was thinking...not sure being on the slide would make it any easier. Just one of many reason why I always buy new
Dtaylor
I would not and here's why: almost all slides are built the same. There is support along the outer edges along the walls. As you near the center and along the coach itself, the only support available is whatever type header the manufacture has put in. Have you not seen pictures of slides that sag in the middle? This can usually be seen on the inside. As the slide sags in the middle, it no longer seals properly and you get water intrusion. The longer the slide is, the more likely you could cause damage causing the slide to sag in the middle.
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
Luke_Porter
I haven't had any problem walking on mine.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
Me_Again
Would you stand on the center of a 14' 2x4 suspended at each end. That is similar to what you are doing if you put your weight (around 230 in my case) on the inside edge of the slide roof near the slide cut out in the trailer wall.
If I had to work up there I think I would cut a couple 2x4 post, carpet the ends and place/wedge them inside the trailer to support the load in the area.
Chris
Weldon
Yes when needed.
tvman44
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
Veebyes
All the time for any reason needing to be there.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
Campinghoss
I walk on mine whenever I need to. I don't jump or shag but it has never caused any problems.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
timberloft
Thanks for the input. I think I will stick with using ladders. Not worth risking damage to the slide.
Walter & Genie
2003 Montana 2955RL
