Carbon-di-oxide alarm goes off when running generator
BC__CANUCK
I have a 2012 Jayco Pinnacle with the factory gas 5500 watt generator and occasionally when we run the genny we get the alarm going off in the coach. This is intermittent and I can't figure it out. I have checked for any loose fittings at the exhaust system.Would wind conditions have a factor? Any help would be appreciated.
2011 FORD F350 KING RANCH DIESEL SRW
2012 JAYCO 36 REQS PINNACLE 2003 HONDA ST/A 1300
1999 CAMARO SS CONVERTIBLE
14 REPLIES 14
BC__CANUCK
Thanks to all. I will make an appointment to have it looked at.
WhitehouseLV
Get a Genturi. Ours did same thing at times. Got a Genturi & never had a problem since
More reading about it
Longtime Member of RV.net (since 2005) just trying to find my friends and way around in this new community.
40' Keystone Toyhauler
2017 Ram 3500 DRW
2019 KTM 300 XC-W tpi
Honda CRF 80F
Honda Rincon
Polaris RZR 800 Trail
steadfastrock
Check to see if your access door on the generator is properly sealed. I had our propane detector alarm when I didn't properly close the access door on our Onan 5500 propane generator. The cooling fan was sucking in the exhaust and blowing it out underneath the coach. (It doesn't cool well that way either).
roam1
Go buy another CO alarm and see if it still does it.
I had a pesky one that always went off and when I bought a replacement, the problem went away.
And I'm still posting years later!
broark01
Wind is a consideration, also if you have the windows open or closed and the vent fans going. I would recommend that if you are running a generator that you close the windows in the 5th that are closest to the generator including the door.
Fresno_Tundra_D
Allworth wrote:
Carbon Dioxide (CO2) makes bubbles.
Carbon Monoxide (CO) makes dead people.
Both of these gases can kill people but carbon monoxide(CO) does it much quicker!
E.Lee Galik
Allworth
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Swamp_Man
Co is nothing to play with. Take the rig in and have it examined/repaired as need. Search death by generator and see all the people who have done very stupid things after hurricanes with generators. I have seen several while I was in LE.
Steve & Trudy Jackson
2018 Cyclone 4005
2016 Ford F-450 6.7 PSD
AirSafe 25K hitch
joelc
Don't fool with CO2. It is a killer. You either have a leak, faulty unit, low battery. Either get it checked by a authorized rep or replace it. Also, check your compartment for any areas where you could have intrusion to the living quarters. I believe technicians might have a meter for this.
DON'T LET IT SIT. GET IT FIXED IF YOU ENJOY CAMPING IN THE FUTURE.
RoyB
I can set mine off just by pointing my tailgate mounted 2KW Honda generator at my trailer. I found this out by accident one time and I now am very conscious where the generator is pointed to. Alot of campers are pretty close to each other in the camp grounds so I make sure the generator exhaust is not pointing at any of them when running...
I also have trouble resetting my alarms once they get set off. I guess it takes a few minutes for the fumes to totally escape from the sensors.
Another thing I do in my OFF-ROAD camper is I have two sets of sensors setup... If both are going off I am pretty sure it is an actual emergency instead of the seemly false alarms alot of these sensors seem to do.
Be thankful for the alarm going off...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Francesca_Knowl
As noted above, you've got a carbon MONoxide detector, and it's going off when you run the generator because the generator makes carbon monoxide and it's getting into the rig.
This is the gas that kills people, and generators have become an important source. And if you have any doubt as to its ability to "rise" into the rig, keep in mind that five people died a couple of years ago when their portable's fumes rose into the rig they were sleeping in. Link.
In that case, the CO detector was disabled...thank your lucky stars that yours is working!
Please don't take any chances- have this thoroughly checked out/repaired before using the genny again.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
motorcycle_jack
I think you meant the CO (carbon monixde) detector goes off. This means you have an exhaust leak. It might have been factory installed but it is not a factory generator, so the exhaust pipe might have bends, welds or joints that are leaking. Any mobile RV tech should be able to find and fix it. Wind wouldn't effect it unless the exhaust has been raised to roof level and your fresh air intake is up there - CO is heavier than air. I suspect your CO monitor is near the floor (it should be by code). If it's near a slide out, floor wall joint, etc. they should look at the exhaust near there. I wouldn't expect you will find it so call an expert.
Sorry, went back and looked at the molecular weight and CO is actually lighter than nitrogen or oxygen so it may rise. But have soemone check it out before you suffer.
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
restlesswind
I can't really help,but you DO need to find out what is causing it!
People die from exhaust fumes!
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
the_bear_II
Sounds like the exhaust from the generator is getting in the trailer. Are windows or vents open ? If so the wind may blow the exhaust in.
You could try getting a piece of conduit or flexible conduit that will fit over the exhaust pipe to extend the exhaust away from the 5th wheel to see if the alarm still goes off. I used a 10 foot long piece of flexible conduit to run the exhaust away from our 5th wheel so we didn't smell it when sitting under the patio awning.
If routing the exhaust didn't work you might want to check the generator box/storage compartment for any possible leaks into the 5th wheel interior.
