โOct-31-2016 02:42 PM
โNov-02-2016 12:56 PM
BigDogF250 wrote:
Nayther, you made me almost laugh coffee out my nose. It's a WW built in 2005, the "common bus" is wire nuts! One more thing I found wrapped in electrical tape this weekend that needs to be replaced.
At this point I am starting with running proper grounds and new positive from the battery to a real common bus, replacing the funky 8 fuse and rigged 3 fuse add on they used instead of a proper fuse panel and seeing where that gets me. Hopefully it's just corrosion or gremlins in one of those systems.
โNov-02-2016 10:50 AM
2btowed wrote:
use meter and check both sides of disconnect switch,move it around and make sure it does not disconnect on its own.Mine did,when replacing it fell apart in my hands...quality.went back with marine grade rotater,works great.
โNov-01-2016 04:33 PM
โNov-01-2016 10:38 AM
โNov-01-2016 10:11 AM
โNov-01-2016 09:04 AM
โNov-01-2016 08:12 AM
Bud
USAF Retired
Pace Arrow
โNov-01-2016 07:01 AM
โNov-01-2016 01:53 AM
DanNJanice wrote:cept he's implying that playing with a ground seemed to make things better?
Just so I understand correctly.
You were running on 12V and everything was working normally. Then suddenly no power...correct?
When you plug in and the convertor takes over, everything works OK...correct?
Sounds like an open between the convertor and the 12Vdc battery. Check all connections, fuses, battery cutoff switches, also find the self resetting breaker(I have seen these fail in just the way you describe).
โOct-31-2016 09:23 PM
โOct-31-2016 08:42 PM
Bud
USAF Retired
Pace Arrow
โOct-31-2016 03:17 PM
