โMar-06-2017 12:37 PM
โMar-07-2017 04:47 PM
tragusa3 wrote:
Thanks for the tip on warm temps. How long do you think I need to tow to have the bearings warm? A few miles?
โMar-07-2017 02:24 PM
TnTtravelers wrote:
Be careful pumping grease into those ezlube bearings. I've heard that you can easily blow out the inner seal and grease will contaminate your brakes. Not a good thing. You should only need to push a couple of pumps in there once a year, if even that. What gives me pause is that you stated that you pumped 100 X into them.
โMar-07-2017 02:08 PM
โMar-07-2017 01:24 PM
โMar-07-2017 06:09 AM
MFL wrote:Cummins12V98 wrote:
I have to say I was impressed at how easy the grease flowed they the bearings. I use AMZ/OIL RED grease.
Glad your EZs worked well for you.:)
Just a tip for others...
Having used this system on several snowmobile trailers, as well as RVs, I'll just add that the grease flows through this system best, in warm temps, and after a tow, hubs warm. I never greased my sled trailers in winter, just before a trip. The EZs have worked for me, with no issues.
Jerry
โMar-07-2017 06:07 AM
โMar-07-2017 04:31 AM
โMar-07-2017 04:26 AM
โMar-07-2017 03:54 AM
โMar-07-2017 03:49 AM
โMar-07-2017 03:42 AM
avvidclif1 wrote:
Bmach
If you pump enough to force the old grease out where does it go???
โMar-07-2017 02:19 AM
โMar-07-2017 01:06 AM
โMar-06-2017 08:20 PM
โMar-06-2017 08:00 PM
