Does This TH Exist?
Bipeflier
Does anyone know if I can find this in a fifth wheel TH?
Less than 35 ft. with a 10 ft. garage.
GVWR in the 14,000 lb. range.
Spacious kitchen with LOTS of counter top.
Quality and decor on par with mid level 5th wheels.
Dove tail rear end to allow loading a Goldwing.
Thanks in advance for any suggestions.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
13 REPLIES 13
TacoMan13
Livin Lite makes what you're after. All aluminum builds. No wood to rot. Counterspace can easily be expanded, but the interiors do look a bit utilitarian. But it's the lightest 32' fw I've EVER seen @ 7k dry with a 10k gvwr.
http://www.livinlite.com/8_5x325thwheel-overview.php
We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.
carringb
maps wrote:
KZ3310T comes close to what you are looking for. Not a TON of countertop space but checks the box for everything else.
Maybe the counter space issue could be solved with a rolling kitchen island?
2014 ORV really big trailer
2015 Ford Focus ST
maps
2003 Super Duty 6.0L, 4x4, some things added and some things missing
2005 KZ Sportsman Sportster 33P
2012 KTM 350XCF
2008 KTM 450XCR-W
MHWASH
The Rubicon 2950 is just over 34' with garage. It has a slide and island in the kitchen. It is a bumper pull though. We just about picked one up, but I'm worried about the overall length. We do a lot of camping in the mountains and an extra 3' makes a difference.
1jeep
keystone carbon 297 under 36' and has a 10 garage.
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
r1Mk
Fuzion 302 or 305 might be the closest fit (or Raptors equivalent). I wouldn't say there is a LOT of counter space, more like adequate. Mine hit the scales at 12,700 holding all my camping stuff and no water, fuel, or toys. It has a dove tail and fairly good decor, but I think that's subject to opinion. The GVWR sticker is 16500
'06 GMC Duramax 4X4
'12 Fuzion 302
Winter 3 sleds
Summer 3 quads
Bowhunter61
Fuzion 302, 34'3" length, 10 foot garage. Dry weight is 11195 so you have very good odds of keeping it under 14K loaded (I do). I load my Ultra into it with no problems.
Only problem is you will have to find a used one.
2015 RAM 3500 SRW
SOLD05 Dodge RAM 3500 DRW 5.9L Cummins
2010 35' Fuzion 302 Touring Edition II
2009 HD Ultra Glide Classic
2001 Polaris Sportsman 500
2005 Artic Cat 250
1997 Kawasaki Bayou 220
1996 Kawasaki Lakota 300
nayther
35' fifth wheel with a 10' garage is not going to leave you much living space. And 14k GVW I think you're dreaming.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Foneguy1
Check out stealth wa2812 ... Not a seperate garage, but in my opinion a very nice floor plan
2011 Forest River Work and Play 25 ULA
2015 Chevy 3500HD Duramax
Silverado LTZ Z71 🙂
Daddy_Bear
I have been on the same search as you. The only one I ran accross that is closest is a KZ Inferno 3010T. Spect show 35' 1" OAL. Raptor 300M, Impact 311 and Grand Design Momentum 328m were my other finds but all are b/t 35' 5" and 35' 11". My wife and I choose the Grand Design. Hopefully picking it up tomorrow. Its a great floor plan...big kitchen/living area, nicely equiped, least hitch weight of the others, and full timing does not void the warrenty.
Good Luck
Drew, Lora & our two boys
Sophie our Toller
2016 Chevy CC, LTZ, LB, W/ Duramax & Allison, B&W Turnover ball and Companion fifth wheel hitch
2015 Grand Design Momentum 328m Toy Hauler
Renology 300W solar
Honda 2000i
n7bsn
If it's physically possible New Horizons will build you a custom one to your exact specs. Of course it will cost, certainly over $100,000.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
azdryheat
Nope, can't think of one. Lots of bumper pulls fit the bill, though. Well not 35' but close.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
352
How are going to fit a 35 footer in a ten foot garage? Is this a trick question?
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
