Dometic refrig/freezer DM2652 - too cold
funpro
How do I control the temp in this refrig/freezer? I have moved the slider on the ribs to the lowest point and it still seems to keep freezing stuff in the refrigerator part, and creating frost on the rigs.
There is no info in the manual as to how to control temp.
Thanks in advance for any answers.
Just returning from Alberta and BC into Montana. 4 more weeks til we get home and would like to see if I can find answer.
7 REPLIES 7
nremtp143
Get a fan like described to move the air around and adjust the thermistor. If that doesn't work, your cooling unit may be failing. Mine did the exact same thing. It froze everything no matter what we did, then quit cooling all together. The cooling unit had a freon very slow freon leak. Take off you cover on the outside and look for any yellowish colored residue, especially around the burner.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
Grady23
If you don't have one yet, be sure to purchase a small battery powered fan that sits in the lower section of the fridge. It helps circulate the air and gives a more even distribution of cold air.
Retired
2010 Cougar 318SAB
2012 Chevy 2500HD Ext Cab Duramax w/Allison
Grady Gulfstream w/twin 150'S
We're Just getting started
edbehnke
you can call demetric and talk directly to them.
it is propably your thermistor but talk to them.
Customer Support Center
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 1-800-544-4881
CustomerSupportCenter@DometicUSA.com
eddie and sandie
3402 Montana 2013
Ford F350 2015
Old-Biscuit
You model of fridge does not have a 'temp control' adjustment....pre-set at factory.
Freezing of stuff in fridge section is caused by three things
*Operation
'Manual' mode vs 'auto' mode. In manual fridge will cool continuously
Switch to 'auto' mode operation
*Thermistor
Faulty thermistor will cause continuous cooling
Thermistor fallen down...not held in clip..causes continuous cooling
Moving thermistor downward will make fridge section LESS cool (you can move clip from right fin to next fin but overall effect is only 6-8*F)
*Bad lower circuit board.....have board bench tested
IF thermistor is faulty you can replace just the tip with this kit
Repair kit link
funpro
To Donn, there are no settings, only a plastic slider
To Pipeman - thanks that's a great suggestions, will definitely try it.
Pipeman
My son has been told that if the slider is on the right hand fin it's set at the coldest. To get to a warmer setting move the slider off that fin and put it on one to the left as you face the fridge. You'll probably have to experiment until you get it where you want it. God luck.
Pipeman
Ontario, Canada
Full Member
35 year Fire Fighter(retired)
VE3PJF
donn0128
What do you have the temp set for on the control panel? Three is generally good.
