Feb-15-2014 05:12 AM
Feb-21-2014 08:37 AM
Feb-21-2014 05:14 AM
Feb-21-2014 04:57 AM
Feb-19-2014 10:02 AM
Feb-18-2014 08:39 AM
Feb-18-2014 03:03 AM
Feb-18-2014 02:56 AM
Feb-17-2014 03:04 PM
Feb-17-2014 03:03 PM
Feb-17-2014 03:01 PM
Feb-17-2014 02:54 PM
Kordog wrote:
Tom, that looks a lot like my list, but the I came across the Momentum line. Bought a 385th right away. Was torn between a Fuzion and a Voltage, but as soon as I saw the Momentum, I knew it was the one.
Good luck with your new TH!
Feb-17-2014 02:31 PM
Macman83 wrote:
I have a Voltage 3905 that scales 16,200 lbs. empty that I pull with a 2010 F-450 that scales 9260lbs with me and 1/2 tank of fuel. GCWR on the truck is 33K lbs. and the bigger brakes and wheels/tires do a great job. On the scale the pin weight was calculated to be 3720 lbs unloaded! That would be a lot of weight for a 3/4 ton truck, and was too much for my old F-350 SRW, even wit the airbags. Just putting out there what numbers I have been seeing.
Feb-17-2014 01:06 PM
Feb-17-2014 05:40 AM
