Electric Brakes for Fifth Wheel
Jimfromvirginia
Need to order new brakes for my 2010 Keystone Montana 3455SA. Want Self adjusting that are 12" x 2", with 7,000 lb axles. Looking for recommendations on brand and good place to buy them online, or otherwise.
2012 Keystone Montana 3455SA towed by 2009 Ford F450 4x4 Diesel
34 REPLIES 34
CumminsDriver wrote:
Try this place on line. I just bought the 12" x 2" never adjust brake assembly for my BIL's gooseneck trailer. Unbolt the old backing plate, attach the new assembly, connect the wires. Reasonable price also.
Rich
I have used this place also with very good luck... And as stated before , I would get the complete backing plate and brake assembly as one... A bit more expensive than just pads but its the whole thing ,magnets , springs , everything!.. Just remember that there are rights AND lefts....
AND E-Trailer is also great online
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Jimfromvirginia
OK, I give!!! How much trouble is converting to disc brakes? Anywhere with a video or instructions?
alboy
The 6750 axel rating is the same that our Newmar Cypress has, actually a derated 7000 lb axel .They come with the smaller brake assembly 12x2. I upgraded mine to the larger brake with no issues.The fiver is approx 15k, scale weighed.I pull with a 2015 DMAX with the integrated brake set at 4 only and have loads of stopping power .I went from a P2 controller on our 06 Ram to the integrated controller on the 15 and the difference was day and night with no other changes.
C_Schomer
Same here. I got tired of replacing the drum brakes hoping for improvement. I didn't even bother on this RV. I put on discs the first time around Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Old-Biscuit
Have you adjusted your brakes??
You do know that being non-self adjusting that you need to manually adjust them periodically due to brake shoe wear.
SDcampowneroper
rednecktrailer.com
Good service and advice.
TheAmRheins
I put new brakes on my 5er once hoping for better results that did not happen. Then I put the disc brakes on and WOW what a difference I can stop the entire rig with just the trailer brakes now. Wish I had installed disc brakes the first time.
Ken & Kathy
Ruben(the cat)& Tiadora (nother cat)
2003 Chev 3500 D/A Dually
2009 Landmark Augusta
Rich1961
Rich
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
RAS43
Dexter is a good brand. Look at the tag on your axles as you may have Dexter axles. That is what I have (7000lb) and my brakes work fine.
Jimfromvirginia
donn0128 wrote:
Instead of spending a few dollars on new old technology, why not upgrade to disc brakes and tow happy and secure in its braking ability.
Sounds reasonable, but staying with electric brakes for simplicity. Looking at these Never Adjust, looking for opinions.
donn0128
momentum_rv
Have you checked to be sure your brakes aren't "greased"?
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
Jimfromvirginia
is it friday yet? wrote:
All I know, is I want better brakes on our Montana 5th. Even after being checked by the dealer, I don't think it stops well enough, even with brake controller at the max. I'm wondering if a disc brake conversion would be worth it.
I am with you. Sucks stopping so gotta do something.
is_it_friday_ye
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
Jimfromvirginia
Montana list these, and I measured, at 12" x 2", axles at 6750 lbs each. Looking at whole assembly. eTrailer has couple of brands, so seeing what others recommend.
