Fresh water dump inside help
boatmanea
We store our Grand Design ST3740BH-R in a barn on our property with a 50A hookup over the winter. In preparation for our RV season, sanitizing and flushing of the water system is a must. The issue I'm having is that when I do this, I need to have it outdoors because I am filling and dumping 80 gallons of water with each step. I have no means to redirect the water out of the barn, which means having to hook up to the truck and drag the RV outside, away from 50A power, for a day or two. This is also the time we're packing and loading up and in Texas, that can mean HOT! It would be nice to have 50A hookups so we can run more than just the fridge for those 2 days. And, the closest level surface to park and do this is about 500 feet from my barn, so a long 50A extension cable is just not an option for me.
So, what I am looking for is a solution to be able to fill and drain the RV while it is still in the barn. Has anyone done this? I can easily route the gray water dump outside, but the fresh water dump gate and overflow tube are my main obstacles. Also, it is really not a realistic option to "bucket collect" 80 gallons of fresh water and move it by hand. Has anyone found a a connector that fits that dump gate and one that fits the overflow tubing so this can be done indoors?
Dump gate outer diameter is approximately 2-3/8"
Overflow tubing outer diameter is approximately 7/8"
(Yes, I know I have measurements and can probably order a bunch of stuff and "trial and error" until I find the perfect fit, but I am trying to eliminate some steps.)
12 REPLIES 12
way2roll
Navigator
Navigator
Curious if the OP ever solved the issue.
laknox
opnspaces wrote:
Go to Home depot and at the order desk order a 50 foot roll of 2 inch pool drain hose.
Hose
Once your order is complete go into the store and buy:
A 64 qt plastic storage container. This is your funnel. Container
Some threaded ABS fittings. Link 1 and Link 2
A tube of caulking
If needed go to Harbor Freight and buy a hole saw kit. Hole Saw
Very carefully drill a 2 inch hole in the end of the container near the bottom. If you press too hard the container might crack. Use a boatload of caulking and screw the two fittings through the hole in the container. Now let the caulking dry for a couple of days while you're waiting for the drain hose to arrive.
For use: Place the storage crate under the drain on the trailer. Attach the drain hose to the fitting using the included hose clamps.
If the hose will not fit over the fitting you might have to buy a short piece or 2 inch pipe and glue it into the fitting. Then attach the Pool drain hose to the fitting. Pipe and some PVC glue PVC glue
When finished disconnect the hose and hang it from a tree or something outside to drain dry. Then roll and store the hose. Put the storage container in a corner somewhere.
Exactly what I was thinking. Cheap tub to catch the water and add a hose to drain it.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Allworth
Look up "pool backwash hose" for a cheaper solution.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Goostoff
Just get a pool hose and adapter and run it out the door. Or worst case turn the pump on and run it down the sink drain and out the gray water dump.
pool vac hose
adapter of sorts
1993 Chevy C3500
2005 Cedar Creek 34RLTS
joebedford
Nomad II
Nomad II
macerator? You can run as much 3/4" output hose as you like as long as there isn't too much grade upwards.
opnspaces
Navigator II
Navigator II
Hose
A tube of caulking
TenOC
Get a sewer cap with a normal water hose connection such as a Camco RV Sewer Cap 39465. Use the onboard pump to drain the fresh water to the sewer tank that is connected to a normal garden hose.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Roger10378
Or get some plastic gutter sections. They snap together and can be undone when you complete the job. Support it with some bricks or wood blocks so that you get some pitch.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
ItsyRV
Have you considered a plain old 3" flexible flat blue pool water discharge hose and a zip tie? And I would think any diverter setup (plastic sheeting and some bricks) would handle and direct anything from the overflow outside.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Cummins12V98
I answered your question on another forum. 1.5" PVC pipe reduced down to a garden hose fitting. Make it a temporary setup or permanent.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
nickthehunter
Nomad II
Nomad II
Hook it up and pull out. Done. I have to drive 5 or 6 miles to get mine, hook it up, pull it home, sanitize it, pull it back to the storage yard, back it in, unhook and drive back home. Iโ€™ve never considered that to be a big deal.
agesilaus
I don't know where you would find 2 3/8 flex hose or fittings. Maybe vacuum cleaner hose?
2 1/2 hose
The smaller hose should be no problem get some double barbed fittings to fit, and add vinyl tubing
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
