Front compartment
grizz272
I have a question about the front compartment on our fifth-wheel. It has a metal floor in it. The center section has a large rectangle that is connected to the rest of the floor by 1/8 inch metal tabs. Any idea Why that is.
Also the rv tech that did the delivery referred to that compartment as the wet compartment. Why?
What kind of things should I not store in there?
12 REPLIES 12
grizz272
This good to know I was planning on putting a wood floor in it , I guess i will not do that now
rhagfo
Our front compartment has a metal floor that is strong enough that I attached my Strong Arms, It also has the battery, and I carry our generator there along with tow larger plastic totes. Part of the space is used for the hydraulics for the slides. Never had water intrusion in the space.
Toolguy5 wrote:
JesLookin wrote:
Mine has same panel in floor. Been holding up strong going on five years now, has never leaked. Never even considered enforcing it.
X2
X3
although I added an Onan 6.5 a year ago in that compartment.. I did not have reinforce the floor in any way,..
When I did not have the Onan, I would store beach stuff in there, chairs, mats, ect...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Toolguy5
X2
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
valhalla360
Nomad III
Nomad III
It probably stays dry when just sitting in the rain but driving down the road, you might not be able to count on spray coming up from below, so most stuff will likely be fine but stuff sensitive to water might be an issue if you pull in the rain.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
filrupmark
Mine has hoses,rg6 cables sewer fittings, extension cords ,work light old Smokey ,Weber Q and things of that nature.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
ugeesta
That is where I put my Weber Baby Q, or Q100 I think itโ€™s called today. Not too heavy and doesnโ€™t stink up the trailer or other storage compartments.
2018 GMC Seirra 3500 Denali SRW
2018 Jayco Talon 313t
2019 Polaris XP1000 Trail and Rocks edition
2016 Yamaha Grizzly EPS
1 wife & 5 cats
JesLookin
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
Old-Biscuit
In lieu of generator that is where I installed DUAL Batteries
Lwiddis
โ€œthe rv tech that did the delivery referred to that...โ€
Why am I worried that the โ€œRV techโ€ has only one weekโ€™s experience? And now works at Walmrt in linens?
dfletch
Yes the cutout is for a generator. Not sure why he is calling it a wet except for the fact that the slots are open to the weather. I would also reinforce the flor to make it stronger and weather proof.
David & Teresa
2017 Cedar Creek Silverback 37 MBH
2017 Silverado 3500HD Duramax 4X4 Crewcab longbed dully
donn0128
Front compartments are usually where the optional generwtor would go. My guess your looking at a vent cutout. If your is simplar to mine the sheetmetal is not very strong. I cut a piece of plywood and screwed it in over the sheetmetal. Has lasted strong for over 12 years.
