Have you checked your brake wires lately?
DHCamper
I urge all to take a minute to crawl under their trailer and look for the following items.
Backing plate strain relief straps not attached. This is a plastic loop that helps prevent chafing at backing plate. All of mine were not attached from the factory. Just wrap the end around the wire and push it in the hole.
Chaffing from contact with the suspension or axle. I notice the sloppy placement of the wires had them rubbing on the components. I restrained and protected them with zip ties and spiral wrap.
Tight wires. You need slack to allow for wheel and axle movement. My wires were stretched tight from the box to the wheels. They used silicone to seal the exit hole which binds the wires. I pulled on them (gently) to get more slack and resealed the holes.
If you don't check for these problems you could experience brake failure due to broken or shorted wires.
Please let me know what you find.
10 REPLIES 10
45Ricochet
greende wrote:
mobilcastle wrote:
45Ricochet wrote:
That and mice think wires are tasty. Hopefully I won't have to worry about brake wires too much longer :W
Do I sense disk brake conversion or a new 5ver with disk brakes??
Yes, spill the beans!!
:B Disk brakes hopefully this year!
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Shadow_Grey
How much for a conversion? Where did you get it from? Seriously thinking that to be a good next mod...that and new 16" wheels with LT tires.
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
greende
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
sk734
Atom_Ant
Rick, what's changing in the future???:@
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
Ginther
When getting new tires put on... Rear axle brakes were non-functional for who knows how long?
2009 Keystone Challenger 34SAQ 5er
2015 Ford F250 Platinum FX4 SB CC 6.7L Diesel
MTPockets1
Mine were rubbing the spring leafs when new, so I used spiral wrap to protect the wires ... all has been fine since.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
broark01
I did and found completely crushed brake wires around the spring shackles. Replaced wires and brake assemblies.
45Ricochet
Memphisdoug
I checked mine this spring and replaced everything. New backing plate assemblies with self-adjusting brakes and new wires on the axles. Should be set for awhile.
2006 Silverado 3500 Crew Cab
2006 Crossroads Paradise Pointe 36RL
