Is 37' to much for a shortbed SRW??
Kevin_O_
Hey guys I need your help... My wife and I are very interested in a 2015 Cougar 330RBK
Specs for 330RBK
Shipping Weight 10065
Carrying Capacity 2380
Hitch 2045
Length 37' 4"
Height 12' 10"
Fresh Water 60
Waste Water 38
Gray Water 76
LPG 60
Tire Size ST235/80R16E
My truck is a 2001 F350 diesel crewcab
9900lb-GVWR
6830lb-RAWR
13,300lb-tow capacity(fifth wheel)
20,000lb-GCWR
I also came across this form that was in with my trucks paperwork stating that I have a camper pkg with 2571lbs of payload.
I was on a while back interested in a similar trailer and received mixed advice. This was before I found this form stating what I actually have for payload. So looking at the #'s I don't think I should have a problem?? My biggest concern now is if 37' is to much for a short bed SRW ?? If it was a bumper pull I wouldn't even attempt it. Of course the dealer says it won't be a problem but I know not to trust them. I have no experience with fifth wheels and could use your help before i possibly make a very expensive mistake..
Thanks, Kevin
KEVIN :C
DW-Debbie :R
DS-Tyler 11yrs old:D
DD-Makayla 8yrs old:p
MERIDEN,CT
2001 Ford Powerstroke F350 Lariat
2012 Keystone Outback 292BH-OLD
2016 Jayco 29.5BHDS-NEW
41 REPLIES 41
lynndiwagon
Russ, yes I did read the post. The OP is not only concerned about the length of the proposed rig but also seems to be concerned about the pin weight. I pull a 40' rig with a short bed Chevy D/A and was concerned about the pin weight also. After much research I determined that one of the main limiting factors of increased pin weight is the rating of the rear tires. To put my mind at ease I installed heavier duty tires on the TV. The length was never an issue, and I've pulled the 40' rig thousands of miles with all types of winds with no stability problems. Hope this helps.....
Lynn & Diana Wagoner
Three Boston Terriers
2011 Chevy 3500HD, DRW, 4X4
2014 Big Country 3650RL
Retired
mdamerell
First off that's a nice looking truck for an 2001. My 2004 F350 weights 8,200# with us and fuel so you will probably tip the scales around 7,500#. 9,900 GVWR - 7,500(guess) = 2,400# cargo. The trailer you are looking at will probably end up between 11 and 11,500# actual with food and stuff. So 20% is 2,300# pin weight.
It's close and as others have said a trip to the scale is in order. Is the empty weight for the trailer from the actual trailer or a brochure? The brochure will not represent the options you may or may not have. The actual dry weight sticker on the trailer should be as it left the manufacturer.
lawrose: nice looking rig but I had to chuckle as my F350 almost weighs the same as your whole rig. Keep the shiny side up and the dirty side down..... 🙂
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
JIMNLIN
The truck camper payload has nothing to do with the trucks payload. Make a trip over to the TC forum and let some of those guys explain.
Anyhow looking at Fords '01 spec pages show a truck camper payload of 2515 to 2684 lbs for the F350 cc 7.3 truck.
Then on the payload pages it shows the F350 SRW cc 7.3 with a 3280 to 3350 lb payload. Looks like another well matched combo like others have said.
Trucks don't carry weight determined by the GVWR. Like all truck your F350 SRW carries weight determined by the axle/tire load numbers.
Many older F350 SRW truck may have around 2800-2900 on the rear axle that has a 6830 lb rating. Subtracting the two has around 3800 lbs for a payload.
Best method is weigh the trucks front and rear axle separately. That way you have the actual numbers to work with.
Short bed ??
A short bed truck with a crew cab has a 156" wheel base which will have no problems pulling any legal length trailer.
IMO much gets put in print about a long bed truck handles better than a short bed truck. That was true many years ago when short bed trucks ran in the 118"-122" wheel base range and our long bed truck ran in the 130-134" wb range.
Todays short bed trucks may start in the 140" wb range and go up in wb length. Bed length is a moot point but handling is more to do with wheel base.... to a certain point.
Dutch_Oven_Man
I don't get into weight wars, but I will comment on your trailer and truck. I have basically the same rig, except a 2002, and a similar RV. The one piece advice I can give is buy a slider. Yeah, it's not always necessary, but it sure makes hitching and unhitching for me much easier. With my old hitch, I could not let down my tailgate. It was a real pain making sure I backed up far enough to raise the tailgate, but not so far back my tailgate hit the fifth wheel. Now, I always slide my new hitch in the maneuvering position so I can raise and lower my tailgate and easily hook up the lights. I slightly bent my tailgate once pulling forward a little to far, so the extra investment is worth it.
Found my slider on Craigslist for $200, so look around.
2oldman
..or seriously.
lawrosa
I don't care what the scales say - you need to go buy the rest of your truck! How can anyone take you serious?
Hmmm... Whats the matter with my set up?:h
:E Am I in danger or something?
Why with my scales weights would I not be taken seriously? :?
Guess I should note my s10 is a ZR 2...
But are you making fun of me or something telling me to go get the rest of my truck? I dont think thats very nice...
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
Mile_High
Kevin O. wrote:
avvidclif1 wrote:
This is hilarious. One guy calls it a F250 and another looked up the VIN and said it is a gasser when the original poster said diesel. I would go with the OP since he drives it.
Here is a Pic of my old girl..
Kevin,
My apologies, I guess the Vin # search thing isn't as reliable as I thought. It has always been right on before.
I reinstate my confidence in your diesel's ability to tow that trailer just dandy. Nice truck by the way, just like my 2001 on only mine was white over adobe.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
lawrosa
Really?? This coming from a guy that tows a 30 ft TT with an S-10?? I sure know who I would rather follow down the highway
LOL .. Thanks for being concerned about me... So that means I am the one you want to follow?;)
If you read my sig its a 24 ft TT.. Actually 20 ft without the tongue..
And if you read my posts im all under weights per catscales.. Not over axles or GVWR..
Now to the OP.. Go get the truck weighed and post back.. Without the weights everyone here is guessing..
Anyway s10 axles are 2700
s 10 gvwr 4900
Here is my catscale ticket to show I am within limits
Note: I drove tractor trailers and hauled 80k many times. I feel I know what I am doing...
Mike L ... N.J.
Kevin_O_
KEVIN :C
DW-Debbie :R
MERIDEN,CT
Kevin_O_
Thanks for all the feedback guys. I think i will load the truck up and have it weighed and find out where I'm at before i do anything.
KEVIN :C
DW-Debbie :R
MERIDEN,CT
avvidclif1
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
Kevin_O_
Mile High wrote:
Mile High wrote:
That truck fits that trailer like Cinderella's slipper! Perfect!
I just looked up that VIN, and I need to retract my statement.
1FTSW31F31EA50875
I just assumed diesel, my bad. That ~14,000 lb trailer is more trailer than that 5.4 gasser and manual trans is going to like. You won't be happy. I'm surprised that 5.4 has enough ponies to move the empty truck.
You must have mixed up some of the #'s? My truck is a 7.3L diesel. And the trailer has a GVWR of 12,445lbs...
KEVIN :C
DW-Debbie :R
MERIDEN,CT
Bird_Freak
1FTSW31F31EA50875
I need to do that also. Never thought it was a 5.4
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Mile_High
1FTSW31F31EA50875
