Mar-19-2015 03:28 PM
Mar-20-2015 10:43 AM
nmdriver wrote:
I think you will find the pin extension does the same thing as the slider. It moves the "centerline" (front edge of the 5er) back from the cab. Now whether or not it is enough for your particular rig depends.
Mar-20-2015 10:30 AM
Mar-20-2015 08:31 AM
NMDriver wrote:... that the extended pin box does not.
Mar-20-2015 08:26 AM
Mar-20-2015 06:52 AM
Mar-20-2015 06:23 AM
When comparing slider and non-slider stories you need to know what rig also had a pin extension and how long it was.
Mar-20-2015 06:14 AM
A hitch extension can take the place of a slider. If the 5er has an extension it may not need a slider and IF you do not have an extension you may need a slider.
A Reese slider moves the front of the 5er back 14 inches, which on most rigs will allow a sharp angle between truck and trailer. A long enough hitch extension will do the same thing.
If your 5er does not already have the extension they can cost as much as the slider rails so you might as well buy the slider.
IF your 5er came with an extension then you need to measure the distance it moves the pin out in front of the corners.
14 inches clears my 2500 6.5 bed cab but it is close.
Mar-20-2015 06:10 AM
valhalla360 wrote:
If he has the same truck ask him to hook it up and see how sharp he can turn.
Mar-20-2015 06:04 AM
Mar-20-2015 05:31 AM
whistlebritches wrote:Same here. My flat front fiver would be 11" INTO my cab at 60 degrees.
We have a 2500 HD short bed and definitely wanted the slider. It will save your cab among other things when you are making a sharp turn. It's definitely worth the money.
Mar-20-2015 05:04 AM
Mar-20-2015 04:49 AM
Mar-19-2015 08:06 PM
BB_TX wrote:
Good friend knocked out his back window on his short bed Chevy with no slider. Did not go buy a slider, but he was far more careful after that.
Mar-19-2015 07:50 PM
Mar-19-2015 06:57 PM
