โSep-15-2013 09:24 AM
โSep-15-2013 10:22 PM
โSep-15-2013 07:22 PM
RedRocket204 wrote:flyinguy68 wrote:
Did I read right? You want to mount a mowing deck on an ATV? If so I never heard of that being done, so I can't comment.
I do however own both a 2008 Can-am Outlander 650, & a 2004 Honda Foreman 450.
Swisher 44" ATV Trailcutterโข Pull Behind
Not necessarily the one I will buy, just a link to show you they exist and as well, MeandMyLabs from post before yours, indicated the same with his ATV. I have no need for a finish cutter so I am interested in brush or rough cutters that can handle mildly off camber hills.
Was curious about Can-Ams but have also read on brand specific forums that X brand quad had pulled out many broken down Can-Ams but I am certain there was some brand loyalty showing in those posts.
I really appreciate everyone who has posted information as it is very helpful. Hope the posts keep flowing.
Thank you to all
โSep-15-2013 06:43 PM
โSep-15-2013 05:03 PM
โSep-15-2013 02:57 PM
RedRocket204 wrote:
Primary use for this machine will be utility, snow plow and towing using a rough-cut mowing deck on my property. Mowing deck will probably only be used twice a summer. Property is not huge but big enough for a riding mower and there is some off-camber sections but nothing significant. Area to be plowed is relatively flat but the bigger issue is right now it takes a while with my snow thrower. I figure if I buy the right machine and accessories, should help minimize time spent plowing/mowing. Using it for jeep trails/exploring will be something I would like to do but is not the priority (have to remember justification for the wife ๐ ). My house is at just under 8k ft. elevation and jeep trail elevations would exceed 11,500 ft.
FI?
PS?
Factory or aftermarket winch (for slow plow)?
Snow plow type recommendations?
At what point is mileage/hours an issue for reliability (if history for proper service has been followed)?
Used models that seem to come up and appear reliable, based upon noob research:
Honda Foreman
Yamaha Grizzly
Looking for additional model recommendations, thx.
โSep-15-2013 02:29 PM
โSep-15-2013 01:39 PM
โSep-15-2013 01:25 PM
Brodie3Az wrote:
Take a mirror to allow viewing the underside of a vehicle that is for sale. look for dents, creases, bends in the plates and tubes.
Check compression for excessive engine wear.
You can always require that the unit be inspected at the local dealership.
Carbuyingtips.com wrote:
16 Tips for Buying (or Selling) a Used Quad
November 19, 2004 โ OK, let's admit it up front. For most of us, money is tight.Real tight.
But you've got to have a quad, either another one of your own for the garage or one for the spouse or one for the kids.
Heck, you're feeling generous. Quads for everybody!
So what do you do?
Buying used is the way to go. Deals may be hard to find, but they're out there.
So here are 16 tips on what to look for when buying a used quad to be sure you are getting the best machine possible for your hard-earned cash. Or, if you look at it another way, here are tips for checking your machine and fixing what needs to be fixed so that you can get top dollar when you sell.
Also, we've included information on how to keep from getting ripped off in Internet scams, which are becoming more and more common.
When you go to look at a used quad, you may want to take this issue of ATVA News with you and follow the tips step by step. It could save you from some serious unwanted surprises after you get the machine home. If the owner has a good machine for sale, he or she won't mind.
Remember, though, you are buying a used machine. So don't expect it to be showroom quality.
Good luck.
1. Have a friend or the owner help you raise the ATV up and stand it on the rear grab bar. This will allow you to inspect the undercarriage for any serious dents or damage.
2. Look closely at the frame, especially the shock mounts, A-arm mounts and intersections of frame components for any signs of rust. This is normally a sign of a stress crack and would require welding and repainting.
3. On 4x4 ATVs, inspect the CV joint boots. They should be in excellent condition. Any crack or tears will allow water and dirt to enter and cause costly repairs.
4. Also on 4x4 ATVs, if possible remove the front and rear differential inspection plugs. If the gear lube looks like chocolate milk the oil is contaminated with water and there could be damage to the bearings.
5. Check the engine oil to see whether it looks contaminated.
6. Shine a flashlight into the gas tank and look for rust. Yes, a gas tank can rush, and rust can cause carb problems.
7. Raise the ATV and support the front of it with jack stands. Then try to move each front wheel in and out from top to bottom and side to side to check for worn wheel bearings and ball joints. Do the same for the rear.
8. With the ATV on the ground, move the handlebars back and forth. This will identify worn tie rod ends.
9. Remove the seat and take the air box lid off. This is often overlooked. An air box can collect water and damage an engine. A clean air box and filter is a good sign.
10. Check all head lights, tail lights, the engine shut off switch and key switch.
11. Check the hand, foot and parking brakes. Do they operate smoothly or stick? Check for damaged or cracked cables.
12. Check the exhaust. Has the spark arrestor been removed? Almost every state and national forest requires that you have one. You don't want to get to a forest and then find out you can't ride because you don't have a spark arrestor.
13. Check for worn out tires or tires full of plugs. It's not really a problem, but worn tires or plugs should be a negotiating point on price. And the tires should be replaced with new ones. If you have never taken a tire off a wheel, don't do it. They are extremely hard to remove. It's much easier to remove a car tire from a wheel than an ATV tire.
14. Look closely at the front or rear sprockets. Each point should be uniform. If they are worn more on one side or have a hooked appearance, a new chain and sprocket set is in order.
15. After you buy a used machine, it's a good idea to change all the fluids so that you know you have fresh oil, etc.
16. Ride the machine.
โSep-15-2013 01:08 PM
dcmac214 wrote:
Any of the Jap brands probably best. We ran into a good deal few years ago, got matching pair of +year-old leftover Honda Foreman 500s. If I'd had a clue as to how very useful they are around the 'ranch' I'd've bought one decades ago. Don't do any plowing or brush hogging with them, but work them HARD hauling, both towing trailers (1 ton trailer & 2-1/2 ton wagon) and trees. And trail riding in Utah. They're nominally 4WD (truly 3WD since there's no lockout for wheels) and I've needed that extra pulling traction a few times.
Don't have experience with ATV snow plowing but don't see how it would be very effective. Used to plow decades ago when we lived in NH and there's no way our ATVs would handle the snows we used to get up there. Maybe if there's a snow blowing attachment it'd work okay.
Friend has a little gas-powered brush hog he pulls behind his ATV. Says it works pretty good.
I would NEVER get a Polaris. Bought pair for Gkids (came with shop manual too), throttle cable on one broke a few weekends ago. Found out (1) shop manual next-to-worthless, (2) frustrating as hail for a shade tree mechanic to do anything more than lube the chain & change the oil. Took 2 weeks to get replacement throttle cable ($$). Found out had to take whole front end apart to replace cable. Ended up breaking choke cable in process of pulling old throttle cable out. I'm now debating whether I bring it to shop and have a real mechanic fix it or get choke cable and take a chance on continuing on my own.
โSep-15-2013 12:38 PM
โSep-15-2013 12:22 PM
โSep-15-2013 12:06 PM
โSep-15-2013 11:10 AM
tmm2good wrote:
My 2 cents, I would stick with the Japanese models. I have had bad luck with Polaris, but some people love them. FI would be nice in your elevation, but not critical, like you said, price goes up on them, so look for a larger bore 5-600 cc and up and as long as it is jetted for your altitude, you should be fine. If you wait till spring, that is when there will be the most out there, and at the highest prices. Look for a maintained machine if you can and the less previous owners, probably better chance of knowing how it was maintained. Once you do decide on one, there are lots of forums that are brand/model specific to help you with any problems that might arise. IN your price range of up to 6K, you should have no problem finding a couple year old quad that is pretty nice.
โSep-15-2013 10:52 AM
โSep-15-2013 10:07 AM
