Michelin Ribs Bad Tires for a Trailer????
cruz-in
Hi All,
On another forum I participate in a poster is claiming:
1) Steel Carcass tires (like the Michelin Ribs) are "bad trailer tires"
2) "The flex/stress put on the trailer tires with steel casements can lead to sidewall failures."
3)"The steel sidewalls are also much more dependent on proper inflation. If the tires are run on low pressure, the steel flexing in the sidewall will fail. It is especially dangerous when you add air to a steel-sidewall tire that has been subjected to the flexing, and it blows out in front of you."
I have never heard this argument before...and I have read lots about tires....You all's thoughts on these claims?
2011 Monaco Vesta
Interesting Coach
This particular one was the prototype.
44 REPLIES 44
Cummins12V98
JIMNLIN wrote:
Once again this long dead thread has risen again with no new posts.
Whats going on ....mods/adm ???
It's weird happens once in a while to me also.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
filrupmark
I have the R-250'S and they have been EXCELLENT . I run Michelins on my truck but went with the R-250's to save a few bucks and have no regrets. Either tire is a great choice.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
gitane59
Strange. I get wmail's about new posts, but find no new posts. Mod's are you deleting stuff so quickly that most member don't even get a chance to view the posts before they get blasted to smithereens for contravening rules? If so why simply not close the thread?
2014 Landmark Savannah, Mor-Ryde IS with Dexter disc brakes, 17.5 wheels with Sumitomo skins,
2010 Ford F350 Lariat CC LB DRW 6.4L Diesel, Firestone Ride Rite Airbags
JIMNLIN
NC_Hauler
JIMNLIN wrote:
buc1980 wrote:
My RIB blowup over the weekend and damage the trailer.I am done with them they are not right for use on the FW.
You have a very heavy 35' Kountry Star that you were using G614 tire at 3750 lbs capacity. You then replaced them with a set of 3042 lb rated XPS Ribs knowing your trailer had right at 12000 lbs on the axles. You ran them for 5 years and 16000 miles and now are complaining because one tire has a bubble on the sidewall and saying their not right for a FW !!! :S
Agree with JIMNLIN, sounds like buc1980 should have had G rated tires and not E rated tires on his 5er.....it has been pretty consistent in here that the E rated XPS RIB be used within their recommended weight limits, a max of 6,000# axles, ( though some who run 3 axle 5er's are able to use them in that application, if again, axles are rated at 6,000#)....I was HIGHLY tempted to put the RIBS on my 5er when I first purchased it back in 07'...I got rid of an 04' Coachmen Somerset that I had put the RIBS on (6,000# rated axles), BUT, tires on the HR are "G" rated tires, 7,000# weight rated axles, so I bid "adieu" to the RIBS and stayed with G rated tires due to the weight of the HR.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Me_Again
Having experience with both now, I think the R250 is the better of the two. Price, sidewall protectors, and tread, gives the R250 the edge.
Cummins12V98
Why are they not right for your 5er?
On edit; Too much RV for the tire????
Me_Again
buc1980 wrote in another post!
"I see a small buble on the side about a 50 mile from the destination but with 6 mile left on the trip it blow up.":S:S:S
But he does win a prize for being the one of first here to report a Rib failure on a 5th wheel.
JIMNLIN
laknox
cruz-in wrote:
Hi All,
$'s to donuts that guy is a tire co. troll. Michelin Ribs are, by what I've read here (and elsewhere) the best you can get for their weight range. The near-twin Duravis R250's are a close second.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
buc1980
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
JIMNLIN
Its funny how this thread was dead for a year and then suddenly showed up yesterday with the last post dec '13.
The OP has went on. Guess someone got bored
Pipeman
I've had Ribs on two 5ers. Not one problem with them. Wouldn't have anything else.
Pipeman
Ontario, Canada
Full Member
35 year Fire Fighter(retired)
VE3PJF
glazier
I think you would have a hard time finding a better trailer tire in their weight capacity, they are very good for 6k Axles
2017 Grand Design Momentum 328M
2015 Chevy 2500HD LTZ Duramax CC/SB/4X4
B&W Companion Slider
