Possible to install larger fresh water tank?
kep5niner
My 5er has an advertised fresh water capacity of 54 gallons. In doing a water test this past summer, in reality it only holds ~ 36 gallons. I called Forest River and they claimed it's actually a 40 gallon tank that truly can't hold 40 gallons, the remaining water capacity is found in the 12 gallon water heater and the capacity contained within the plumbing throughout the trailer. I called BS to the FR rep, and he agreed...
That still doesn't do me much good as far as fresh water capacity. We don't dry camp much, but most parks we frequent have only electric at the sites.
Here's my question: is it possible to remove the existing 40 gallon fresh water tank, and replace with something larger? I haven't looked at the physical constraints yet (underbelly), but I have plenty of CCC in the 5er for additional water, and would structurally support it as required. I've seen up to 96 gallon fresh water tanks - again, not sure if it would even fit yet.
I searched the forum to see if this topic has been addressed before, and did not come up with anything.
Has anyone swapped out their fresh water tank for a larger one? Thanks!
2016 Salem Hemisphere 368 RLBH / 2014 F250 Platinum 6.7 Powerstroke / 2011 Bayliner 315 / T/5.0 MPI
30 REPLIES 30
4Kellys
I guess if you don't care about your trailer warranty, go for it!
24v
I am ready to do the exact same thing, but on a much smaller trailer. I have a Hideout 177LHS and it only came with a 20 gallon fresh water tank. I sourced a 52 gallon tank to replace it. My grey and black are 30 each, so I am putting in an extra pump that will use grey water to flush the toilet. The combination of these 2 mods should give us quite a bit more usable fresh water.
I bought a Ronco tank from plasticwatertanks.com
Both of their sites have lots of info and many different sized tanks. You can even tell them where to put the fittings. In my case I had them place them the same as the stock tank, so I should be able to just swap it in place of the other without messing with the plumbing there. It took about 2 weeks to get from time of order.
coolmom42
mhardin wrote:
Even if you don't have room for a larger tank, you may have room for a second tank somewhere. Or, you could put a tank in the bed of the truck and use a transfer pump to move it to your main tank.
This.
Or you could possibly add another tank under the bed. Plumbing could be tricky though.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
kep5niner
Great information and ideas. The capacity of my gray is 60 (30x2) gallons and black is 30 gallons. I guess I won't know the feasibility of this project until I open up the underbelly.
Aridon
Doubtful you'd get that much extra space to add significant capacity to justify the high costs.
You could just use a bladder on your truck and transfer the water if needed. That would be relatively cheap and would solve the problem.
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
dewey02
It seems that RV companies routinely count the amount of water in your water heater as part of the capacity. In reality, you can NEVER make use of those gallons because it takes water in your FW tank to push the water in your water heater tank out to the taps. If you FW tank is empty, that extra 8 or 12 gallons in your water heater just sits there.
You can open the water heater tank drain or low water drain and access that water in an emergency. So while it is true that technically you have those gallons on board, they are pretty useless to you.
As far as them claiming a 40 gallon tank is on the rig but in reality it that hold 40 gallons, that is just false advertising on their part.
Veebyes
I guess running out of water is no fun at all. A high water capacity was on our 'must have' list & we scratched anything under 80gal off the possible purchase list.
As a previous poster noted you will have to open up the bottom, have a look & take some measurements. Chances are you will have room to install something much larger.
We have 100gal total & it is reassuring when we do not have water at the site knowing that we are good for 6 days easy.
Nothing wrong with the bladder in the truck & pump method if a little inconvenient.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
FLY_4_FUN
For the work and expense involved in plumbing in a new larger tank, I would just get a semi-custom water tank for the truck. I got a 33 gal tank and 12v transfer pump/fittings for $200 and can remove it for all but the required trips. I actually don't need the pump with my current rig as I can select winterize and it sucks the water out of the tank into the rv. Its a nice option if you have the space in your bed.
Daryll
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
laknox
korbe wrote:
I had to fix the FW tank supports once and while down there, I was able to see how the tank was supported and how it could be modified - or enlarged. Mine could be increased by width and length, but not the thickness. And then I would need to see what dimensioned tanks are out there.
When talking cubic, it only takes a few inches to gain quite a bit of capacity.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
korbe
laknox
I've seen guys put a small bladder tank on their roof, ~20-25 gal, with a simple gravity feed. Also seen guys with a larger bladder tank in their truck bed with a transfer pump. Personally, I carry 2 7 gal "blue cubes" with me to our long weekend boondocker. One I'll use for hand-washing and tooth brushing outside; the other is a "spare". I've dumped both in my fresh tank on one occasion. Most times I'll dump whatever's left in both of them in the black tank for the drive out and to the dump site, about 30 miles away. If anything is left after that, it goes to help put out the camp fire.
Lyle
mhardin
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
Nunyadamn
What size grey and black tanks do you have. You will have to verify you can hold that water somewhere. I have a 86 gallon fresh but only 35 gallon black and grey tanks. Usually we fill the grey tank really fast and have a bunch of fresh water left.
For your trailer, I think it is possible, anything is possible. You will have to see what can fit for your specific setup. If you have the room, replacing the one tank with a larger tank would be easier, but if you can't fit that one, you could use two tanks and run a line between the two - water will find a level so it will make both tanks equalize. That should feed water to the tank with the pump outlet.
It's a pain, but if you really need more fresh water you could get some of those large 5gallon fresh water jugs from camping world and fill your fresh water tank. To make it easier, get a fresh water pump and pump from the external jug to the fresh water tank on your trailer.
2014 Jayco Jayflight 32BHDS
2015 Ford F250 Lariat 4x4 Crew Cab 6.7L Powerstroke
Allworth
Icon-Direct (Google them) may have other tank sizes available that will fit your space.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
agesilaus
No use even speculating until you get under the fiver and drop the coroplast so you can see where there is room.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
