Sep-06-2015 04:58 PM
Sep-10-2015 07:14 AM
Sep-09-2015 08:27 AM
Sep-09-2015 06:53 AM
Sep-09-2015 06:31 AM
Sep-09-2015 03:34 AM
austinjenna wrote:
How do you guys pre-cool the fridge and how long does that take? Currently I go to the storage lot and fire up my fridge the night before we leave. Would a residential be able to do that for lets say 12 hrs maybe running off 2 12volts?
We store our RV at a storage lot that has no electricity (for us), I usually go over early in the morning to start the fridge. We load it up later around noon or so and it's plenty cool by then. I simply turn on the inverter and the fridge starts running, very simple.
If you have your batteries fully charged when you start up the fridge, running the fridge for a day, day and a half shouldn't be a problem. I did it with two six volt before I hooked up the solar panels. The solar will keep up with the fridge, my trouble is here in Wisconsin I don't get 100% sunshine so if we have a couple of "grey" days in a row my solar power is pretty much zilch until the sun shines again
Sep-08-2015 12:57 PM
Sep-08-2015 12:41 PM
Sep-08-2015 09:08 AM
pcm1959 wrote:
I have 2 6volt group 24 batteries and a GoPower 1k watt inverter.
I do not use the inverter for powering the fridge while on shore power. My inverter is dedicated to the fridge and has an auto switch over between shore power and inverter.
Sep-08-2015 06:14 AM
Sep-08-2015 03:29 AM
Sep-07-2015 11:19 AM
Sep-07-2015 10:56 AM
Bellpr wrote:
the Wife and I are shopping and we see a lot of fivers with residential Fridges and Inverters in them now. Are they really more prone to breakdown because of the bouncing around in the trailer or it is just folklore? Should I just go with a Large Gas/Electric fridge? Do the Residential fridges last long on the inverter and dedicated 12 battery? Should I consider a Onan generator? How the heck do you winterize a residential fridge with Ice and Water in the door? I know a lot of questions for one thread... Any suggestions? Thanks in advance for your input.
Sep-07-2015 07:50 AM
rjxj wrote:
I still have a Dometic but read all I can about residential. If I do get one I dont think using it in an RV is an issue. I dont drive fast on dirt roads, I usually crawl so I dont think I would be hammering it enough to hurt it. Maybe I'm wrong? My concern is mainly energy use. I have four 6 volts and 520 watts of solar. I dont think I would have a problem and might only have to run my Honda 3000 if there were a few bad days. I have had a couple people tell me that they had friends that had them and couldn't install on enough solar to keep up. Who knows what their install was like? Maybe they wired it with 16 gauge. Sounds like BS. It's just a matter of crunching the numbers for each model and figuring out their expected energy use is. My solar stuff is new so I'm not 100% in tune to how well it will do this winter. I have a Bogart 30 solar control and a Trimetric so I will be able to monitor it better this year.
:R
Sep-07-2015 07:13 AM
Sep-07-2015 05:50 AM
