Jul-31-2015 07:33 AM
Aug-04-2015 01:06 PM
Aug-04-2015 05:57 AM
Aug-03-2015 08:07 AM
Aug-02-2015 09:10 PM
Aug-02-2015 01:32 PM
C Schomer wrote:
My 5er came with a SW/5th AB but I have a LB so I removed the SW and reused the 5th AB and moved it back 10.5" to do away with the ext. pin position. I towed it home 1000 mile with the SW and I couldn't tell any difference from a solid pin box. After removing the SW, I still couldn't tell any difference.
My hitch is 3" in front of the axle and the pivot point of the SW was 9" behind the axle. The pivot point of a bumper pull is about 4', maybe even more, with a WD hitch sticking out farther. I'll take the 9" behind the axle any day over a bumper pull! That little bit was undetectable even when I went back and forth with the SW and the pin positions. I have friends who put their regular 5er hitches 6"- 8" behind the axle, on their SBs, so they wouldn't need a slider and that also worked fine. A heavy slider would be the very last resort for me. I'd find a SB friendly 5er and mount the hitch farther back if I needed a little more. Craig
Aug-02-2015 12:43 PM
Aug-02-2015 09:20 AM
Aug-02-2015 08:27 AM
Learjet wrote:N-Trouble wrote:sfpcservice wrote:
The sidewinder in my opinion turns your truck back into a bumper pull by moving the pivot point behid the rear axle.
No, moving the pivot point back doesn't affect how the load is distributed. Weight is still over the TV axles so its still going to tow like any other 5er in that regard.
How does the physics of this really work?
yes the weight is still over the axle, but an arm is locked to hitch that extends reward.
So, any side, load such a semi pushing on the side of trailer would generate leverage on this arm...thus twisting around the hitch. So yes similar to a bumper pull...but with a shorter arm.
Aug-02-2015 07:42 AM
Aug-01-2015 06:06 PM
Aug-01-2015 02:46 PM
Aug-01-2015 02:42 PM
JeffPritchard wrote:
Newbie to 5th wheel arena.
I'm in the throes of figuring out my next rig.
I'm planning to go with a short bed "half-ton" (nay-sayers, please hold your tongue this time...already hashed that out in another thread. 🙂 )
I have looked at a fair number of youtube vids about the awesomeness of both sliding hitches and sidewinder/revolution pin-box approach to avoiding collision between trailer and rear of cab.
I can't seem to decide yet which is "better". Any of you have tried both and can compare/contrast the two approaches?
Aug-01-2015 01:44 PM
Aug-01-2015 11:23 AM
Aug-01-2015 11:22 AM
JeffPritchard wrote:N-Trouble wrote:
I assume by short bed your talking 6.5" and not the little 5" beds you seen on some of the newer 1/2 tons?
Sliders are heavy and you likely don't need one with most new 5ers have tapered nose caps. The Andersen hitch moves the pivot point back ~5-6" which gives some additional clearance vs a non-sliding hitch and in most cases will get you to 90" with a 96" wide trailer.
For you application I would highly recommend the Andersen Ultimate Aluminum hitch which comes in at only 30lbs,
Finally googled this thing. Very unusual. Lots of interesting good features.
I wonder though...how difficult is it to get that ball lined up perfectly enough when you're docking? On the one hand, you would be able to see it out the back window...but on the other hand it looks like a less sloppy connection than a typical ball hitch. Any troubles with that?
