โOct-17-2014 06:46 AM
โOct-20-2014 06:06 PM
JIMNLIN wrote:Retired wrote:
Using the slider puts some wag into the tail like a travel trailer. Wag that makes it easier to control backing up a 5th wheel.
Users of slider hitches - do you agree?
100 percent.
Not a new thing as manual operated sliding hitch owners have been doing this since the hitch industry gave us a sliding hitch and advertised that fact
JIMNLIN, I wish that they had advertised the fact that a slider adds to maneuverability when backing up. There was nothing in the manuals with my Curt Hitch. I also researched forums about techniques in backing a FW. Nothing ever mentioned about using the slider to cause FW to turn more quickly and tighter.
It may have to wait until next spring, but I would like to do a controlled experiment in an empty parking lot with painted parking lines. Start with unit at the same exact spot, with FW and truck in a straight line.
First time with hitch in forward position; kingpin over the axle. Crank wheels fully over and back up until trailer is at tight angle. Measure the angle and the distance to the rear the trailer has moved.
Second time with the slider to the rear: kingpin behind the axle. Crank wheels fully and back up until you reach the same measured angle as first one. Then measure the distance to the rear the trailer has moved. It should be less and would be basic way to measure the tighter turning circle enabled through use of slider in the rear position. Will be interesting to see what difference there will be.
โOct-19-2014 05:52 AM
โOct-19-2014 05:33 AM
My limited experience of two years with a 5th wheel was preceded with 20 years of travel trailer experience. I found it much more difficult to back up with a 5th wheel, especially if you are trying to reposition the unit a few feet to the side while backing.
โOct-19-2014 05:06 AM
โOct-19-2014 03:35 AM
โOct-18-2014 06:48 PM
Retired 02 wrote:right on.. I could put my tt anywhere and then with the 5er you have to set up and now I can put that longer trailer in tighter spots then the TT, the set up is the key, get the front tires in position before you place it in reverse
the key to backing a FW is all in the set-up.
โOct-17-2014 03:20 PM
โOct-17-2014 10:09 AM
C-Bears wrote:
Yes and no. What you are saying is correct. In my younger days I drove truck/tractor/trailers. There was a noticeable difference in backing up a conventional tractor (long nose) and a cab-over type tractor (no nose). When you change pivot points, weather it be the capture plate, the sliding rear axles on the trailer, or a shorter front steer axle difference, you change how that rig handles backing up.
What I believe makes it easier for most folks to back up their FW's is practice, practice, practice, and doing it the exact same every time. I suppose if you were going to slide your hitch back each and every time and always did it that way then it could be a good way to go.
โOct-17-2014 08:59 AM
โOct-17-2014 08:43 AM
โOct-17-2014 07:26 AM
โOct-17-2014 07:01 AM
