spring hanger reinforcing
nayther
I remember seeing a post/thread with pictures of a kit that someone makes that ties the spring hangers together for strength. I've searched various combinations of reinforcing, spring hangers, etc. and not found it, anyone remember where it is? My frame is cracked right above all the hangers and I'm going to weld it up and gusset around the hangers but I think this would stiffen up things much better.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
9 REPLIES 9
nayther
I'm going to design something and add it like suggested between all 3, would be nice to see what Lippert does. I don't want to weld anything in there because I'm afraid I won't be able to remove my fresh water tank (it's one 150 gallon monster and it has a leak that I need to fix). So need to be bolt ins.
We're fixing the cracks today and adding some gussets on the outside of the frame. Probably won't get to the cross tubes today though.
DIRT BIKES RULE
tinner12002
joebedford wrote:
I used C channel welded across the front of the front hangers and rear of the back hangers (on my old RV). That completely stopped the breaks.
I like this idea as it gives strength to both the inside and outside of the hanger!
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
joebedford
Nomad II
Nomad II
Crazy_Cooter
I just weld in 1.75x.083" tubes between hangers on all the ones that come into the shop. 20' stick usually does tandem axle.
1999 Peterbilt 385
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2010 NuWa Hitchhiker 36LKRSB
2012 Cyclone 300C Triple Axle
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
Bedlam
Moderator
Moderator
Lippert created a kit to fix weakness in their frames. I'm not sure if they were just part of a recall or whether you could buy them.
nayther
interesting that this kit just goes between the center hanger, not the front/rear hangers, that's where mine is cracking.
DIRT BIKES RULE
nayther
Thanks, that's what I was looking for. will use this as a guide/template and fab. something myself.
DIRT BIKES RULE
Old-Biscuit
Didn't know there was a kit.....interesting 'rjxj'
What I have seen is 2" square tube cut to fit and welded between opposing spring hangers and welding a plate across spring hanger (closing up hanger into a 3 sided one)
