Still have water heater issue.
portliz
Well top valve is open. Bottom valve is open. Middle valve is closed. Now no water at all coming out of the hot water taps. Cold water taps OK.
15 REPLIES 15
nomad297
Did you get this worked out?
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Dakota98
portliz wrote:
After running through some problem solving steps we think it might be a check valve. We did a combination of open and closed valves. There is hot water in the water heater. It has pex lines and valves. We think the cold in line valve was put on wrong ( just checked and winterized by rv dealerhad it ). Once we put the cold valve the wrong way!!! We have water again from all taps including outside shower but not hot. It is so awkward to see and get to. Guess our next step is take it to an rv repair place. Anyone know a good one near Troy Alabama. Thanks for all the suggestions.
"We think the cold in line valve was put on wrong", just had it checked & winterized.
Was this by-pass system just installed or repaired at the time ?
If so, that would have been good information in your original posting.
Water pressure, but NO hot water & inlet valve in "closed" position, but is really "open", and in consideration of what you've described earlier.
Then the By-pass valve is also wrong.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
portliz
After running through some problem solving steps we think it might be a check valve. We did a combination of open and closed valves. There is hot water in the water heater. It has pex lines and valves. We think the cold in line valve was put on wrong ( just had it checked and winterized by rv dealer). Once we put the cold valve the wrong way!!! We have water again from all taps including outside shower but not hot. It is so awkward to see and get to. Guess our next step is take it to an rv repair place. Anyone know a good one near Troy Alabama. Thanks for all the suggestions.
Old-Biscuit
ScottG wrote:
I've never seen a check valve on a three valve system - there would be no reason for it.
I suspect you still have a valve in the wrong position. Try turning one to see what heppens. If no luck then keep trying.
X2
Think that cold inlet OR hot outlet valve handle is stripped.
Handle turns but valve is still closed
IF sure water is in WH tank---verified by opening relief valve then the hot outlet is still closed.
Remove handle and open valve using pliers on valve stem.
ScottG
nomad297
Beaker wrote:
You have a bad check valve.
IF they have 3 valves, which husband says they have, there would not be a check valve.
This though gives a thought that perhaps there is a check valve.
Has OP checked{by overflow valve) to see that there is hot water in the tank?
They have a bad check valve.
Bruce
Beaker
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
newman_fulltime
portliz
Do you mean installed wrong or in wrong position? It should be opened so water goes into the tank. We have used this before no problem so don't think it is installed wrong.
portliz
OK DH insists that the valves are in the right position. There is no air coming out of the hot water tap and no water coming out at all. Water coming out of the cold water taps. Hot water tank filled. Guess we must have a bad valve in the hot water out line. Correct?
newman_fulltime
your inlet valve handle is on wrong turn to cposed and see if you get water
nomad297
Bruce
RoyB
This has probably already been discussed but the VALVES for winterizing are elongated as shown in this pictorial.
Are your valves showing this as well...
This is a typical trailer water flow diagram that may help as well..
Pictorials from GOOGLE IMAGES
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Dick_B
Are you SURE the valves are in the positions as stated?
Did you allow enough time for the HW tank to fill up? Does air come out of the hot water taps?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
