โJan-07-2014 07:54 AM
โFeb-10-2014 12:47 PM
โFeb-10-2014 12:42 PM
gpshemi wrote:
Installed mine myself. I drilled a small hole first to see if it was on center, then drilled the big hole to compensate. Was fairly straight frward. I did run into a glitch though with my airbag mounts trying to clamp over the hitch plates. They use the same section of frame.
โFeb-10-2014 12:29 PM
โFeb-10-2014 11:06 AM
โFeb-08-2014 05:41 AM
โFeb-07-2014 05:58 PM
โFeb-07-2014 02:51 PM
โFeb-07-2014 02:30 PM
โFeb-07-2014 10:25 AM
B.Sjulestad wrote:ol Bombero-JC wrote:B.Sjulestad wrote:
I had mine installed by the place I purchased from. $1300 installed.
Yikes!.:)
Wow!
Holy hockmier, Batman - $600. an hour!!
That included the hitch
โFeb-07-2014 07:20 AM
โJan-14-2014 06:56 PM
Infinityrver wrote:
Check out the Demco Super Slide. You don't need a capture plate. Each time you purchase a different 5er you won't need to get another $ 150.00 capture plate.
The Demco will be my next slider unit.
โJan-10-2014 12:51 PM
โJan-10-2014 08:23 AM
โJan-09-2014 04:45 PM
