Tire time! No china bombs
Madhatter1
39' Fuzion triple axle 15K loaded. Been using Maxxis Load D with good results but want to go to a load range E. 225/75 15". Anyone hauling long distance and heavy that cam make a recommendation for what works these days?
Thanks in advance.
33 REPLIES 33
walker111
JIMNLIN wrote:
walker111 wrote:
Keeping an eye on this as I may buy tires soon. Bought a 2014 Voltage 3305 recently and is in great shape as it should be. The tires are 235/80R16. Name escapes me but starts AK......
They show some wear but ok. Trailer weighed is 12700 and know I will have 1500 more in there towing and will upgrade tires in the future. It is double axle.
Keep recommendations coming....
Were hijacking the OP tread here but maybe he can benefit from your trailers completely different tire needs.
The OP has ST225/75-15 D tires rated at 2540 lbs and 28.3" diameter.
He can upgrade to 16" trailer wheels and a LT225/75-16 E at 2680 lbs @ 29.2" diameter. His tri axle trailer probably has 5200 lb axles.
Your tire needs are different.
Your ST235/80-16 E has around 3400-3600 lbs capacity and your tandem axle trailer may have 7k axles.
If this is the case the only LT tires that will work is the Sailun S637 G load range at 110 psi or the Goodyear G614 LT235/85-16 G load range at 110 psi both are a commercial grade all steel ply carcass and tread.
Now if your trailer has 6k axles the LT235/85-16 E at 3042 lbs capacity tire will work for you. If your trailers gross weight is close to 3000 lbs per wheel I would stick with the Michelin XPS RIB or the Bridgestone R-250 both are a commercial grade all steel ply carcass tire.
Ordered a set of sailuns 235/80R/16 this morning.
brirene
If you're referring to the crease in the 225, that's not unusual, and is part of the manufacturing process. My marathons had those also. I can't speak to the quality or performance of the Towmax tires as I've never owned them. Only giving you my experience with MIC Marathons. Good luck!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Ram2500Chip
brirene wrote:
Sorry, but I think the whole "China bomb" thing is overblown (no pun intended), especially in the last several years. When was the last time you saw a post about it? I got 5 years and many thousands of miles from my previous MIC Marathons, have replaced them with Carlisle R/H. Tows nicely and I expect good service from these as well. Get a load range higher than the originals, maintain and cover them. YMMV.
I was hoping that you were right.... but after taking delivery of my new 5th wheel, I am astonished at the tires. Powerking Towmax. The sidewalls have creases (I was expecting) and bulges, that I was not!
2016 Wildcat 29RKP, 2016 RAM2500 6.7 Cummins:)
Bad_Brad
I just replaced the tires on the triple axle raptor we bought new in 2008 with Maxxis. Knock on wood, I've never had trouble with tires. I believe part of my luck lyes with the fact that both my trailers have had 16" rims/tires. I don't know anyone personally who has had problems if the tire/wheel size is 16", but I know many who have had problems with 15".
2023 Ford F450 Lariat, 6.7 H.O., 10 Speed
2018 Grand Design Momentum 394
2010 Polaris RZR S
2014 Polaris RZR XP 1000
2 boys 26 & 23 yrs
A Super AWESOME Wife of 38 years
JIMNLIN
NHIrish
Madhatter1 wrote:
Wow, thanks for all the responses. I checked the trailer today and I have plenty of room for 16" wheels so may just do that. As for china bombs, well........been china bombed and never again. Maybe they are better now but I'll give then 20 years to prove that out. Going to look at the Firestones. E rating is max I need.
Any sites that sell decent 16" wheels?
Thanks again.
Make sure you buy wheels appropriate to the offset requirements of your axles. Specs should be easy to find on axle mfg. website.
2016 Heartland Bighorn 3270RS
2010 Carriage Cameo 32-FwS
2008 Carriage Cameo
2006 Keystone Cougar
2005 Keystone Zeppelin
1999 Coachmen Catalina
2017 Ford F350 Powerstroke
Curt Q25
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
:W
BigDogF250
Trailer-wheels.com is where I got mine because they had the factory looking wheel in the 16". $70 each and free shipping, plus he was in Southern California which made the delivery quick for me.
WW 16" Wheel
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
1jeep
funny the tires that ive had the worse luck with were the GY marathons that were on my previous trailer, all were only a few years old, in one month two had tread separation.
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
tinner12002
Thanks again.
When I upgraded both my RVs from 15" to 16" I found wheels on ebay new 6 lug rims for $45 each...not sure if he still has some but it would be a place to look. I run the Maxxis on both with no issues.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
walker111
Thanks guys. They are ST.
BigDogF250
brirene wrote:
walker111 wrote:
They show some wear but ok. Trailer weighed is 12700 and know I will have 1500 more in there towing...
Best to check the dates on the tires as age, not necessarily miles or tread, are the important consideration here. Even though the unit is a 2014, the tires may be older.
x2,000,000
All of mine that failed (4 total) had great looking tread, it just separated from the rest of the tire. As early as 40 months from MFR date and as late as 54 months from MFR date. (And some made it to 5 years no problem.)
brirene
lincster
If they are ST, get rid of them.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Strabo
sunnybrooktoyhauler wrote:
I have a triaxle trailer also. I was blowing rear tires all the time. Went to the Firestone transforce lt tire. Knock on wood no blowouts for the last 3 years. Something to ponder. Good luck
Same tire i use, xlnt choice.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
