Tires, anything different if we have a Toy Hauler?
porkchop1221
We have a little bubble on one of the tires... We have had the Heartland Cyclone 3010 since May 2012. I know we need to change it and I believe all four should be changed.
Is there anything specific or different for Toy Hauler/5th wheel tires that I should be looking for?
Any suggestions on which brand etc? Does TireRack carry these tires? Costs?
I would like to order it online b/c I think it might save the most money, but where would I go to have it changed out? I don't think my Local Walmart would do RV tires.
I'm sorry about the newbie questions.
2012 GMC 3500HD, Diesel, Crew Cab Standard Bed, SRW
2013 Cyclone 3010
Toys:
Ducati 749R
Aprilia RSV4
28 REPLIES 28
christopherglen
Skimp on dinner, spend the money on tires - not to have to spend the money on tires again. I would to up a load rating (I did - from E to G) and have a greater cushion. The main reason for tire failure is overloading - as the pressure in the tire drops the load rating of the tire drops. 5-10 psi low and the "correct" rated tire is overloaded.
This may be a good time to start researching TPMS.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
2500_Grunt
2btowed wrote:
Sitting on the side of the road in 110 drgrees,looking at the damage done to your refrig,heater and entire side of your trailer,is not the way you'd like to START,your week of vacation....and that was only the begining,then you deal with tire companys..it's not my fault,your RV dealer..it's not my fault,insurance...it's not covered and all you wanted to do was go relax and unwind.The best money you will spend is on the tires.....You can't have fun if you can't get there,everything else is easy. My 2 cents.Been there done that. Now have ribs.
Exactly!
2005 Dodge 2500 5.9 SRW long bed
2014 FS28 Evergreen Amped TH Blue Ox 2000# WDH
2300CC VW turbo 4 seat sandrail, Yz450f, 350 Raptor quad
lincster
Do not put on a ST tire, they are all junk.
Michelin XPS Rib is the best E rated LT tire on the market, IMO.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
2btowed
08 Ranger/sold/14 rzr900 4
08 Grizzly x2
06 400ex
06 Honda 90
08 f450
04 Kymco 110
Steve_O_Reno
Bigburd wrote:
Went with 17.5" and Goodyear G114's. Never looked back.
Me Too!!!
porkchop1221
Yes Dougford. Not happy but also not suprised about the bubble. I will see if there is a discount tire close by.
Also change ALL the tires right? I'm sure we will have problems with the other three soon.
dougford wrote:
Wow, can't believe it already has a tire issue. Anway, I've used Discount Tire before. their prices are reasonable, and I just parked the camper (it was a 20-foot bumber pull at the time) in their parking lot and they mounted the tires. Not sure you have a one near you. I would also ask Walmart. You never know what they might do...
2013 Cyclone 3010
Toys:
Ducati 749R
Aprilia RSV4
porkchop1221
Thanks all for the suggestions. I'm sorry I'm unsure about the load. We would at times carry 3 motorcycles in the back - I can look up the weights - we also have the extra fuel tank as well. Dry weight is 394 lbs for two of the motorcycles and the other motorcycle is 423.3 pounds wet, so approximately 1200# of motorcycles. Of course that won't include all the other incidentals like extra gas, water, food etc etc.
Thanks Y-guy, you are probably right. I will look around for prices and see about costs. There are a few RV dealers near me - and of course Camping World. I'll do a search and find out about prices. I appreciate the help!
2013 Cyclone 3010
Toys:
Ducati 749R
Aprilia RSV4
jgos929
I use the Power King Towmax ST tires from Tire Rack. I had them on my travel trailer for several thousand miles without any problems and I'll be putting them on my toy hauler as soon as the tires on it need to go.
People on here are gonna give you******if you don't use GoodYears or Maxxis etc.
TV: 2012 Dodge Ram Crew Cab HEMI
TT: 2006 KZ Jag 29JB
Bigburd
Have a 2012 Cyclone 300c. Bubble on sidewall after a trip. Went with 17.5" and Goodyear G114's. Never looked back.
2012 Ford F-450 CCDRW 6.7L
2013 Heartland Cyclone 300C / Goodyear 17.5" G114's / CarryTank 200
2006 Club Car
Bigburd
2006 Club Car
Y-Guy
Moderator
Moderator
The few bucks you might save online will be spent mounting and balancing. Do some local work and get some prices, then compare online. Then you can negotiate with the local guys.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
JIMNLIN
ST or LT or even P tires with the proper capacity are used on trailers. Type of trailer doesn't make any difference to a tire.
If your present tires are the low cost made in china special trailer (ST) I would up grade to a USA branded LT with the proper capacity. If one is showing delam signs then the others aren't far behind.
You left us in the dark as we have no idea what size/load range tires your inquiring about.
mustangglp
A toy hauler will have a higher GVW. I would go to a LT tire with the highest load rating I could find and not made any where close to China
Gary
dougford
2008 Ford F350 CC 4X4
2012 Jacyo Octane T29A
2006 Yamaha Blaster
2007 Honda Recon
2006 TTR50
2012 YZ250F
2013 WR250R
2013 XT250
