to grease or not to grease
blacktop
I have one of those greaseless plastic rings on the pin box. I'm thinking that I should still grease the pin. What do you use, white grease, bearing grease, WD-40 or something else?
12 REPLIES 12
jffnkrn
i have the white grease spray that works well to apply to the internal moving parts, just a spray film on it works well. i also have the plastic/nylon disk so no grease on the plate. I also got a hitch cover on Amazon with blemish for $20 bucks. keeps dirt and crud out and off. Dirt is not good for it as we know, and WD-40 may attract dirt etc. Good Luck & Be Safe ! ! !
tvman44
I also use this on my pin.
Garry&Gayle wrote:
Been using this for years on my pin Reese
Papa Bob
Husky 16K hitch, Tekonsha P3,
Garry_Gayle
Happy_Prospecto
On the King Pin I use the grease that is in the grease gun. I do not believe it really matters what kind of grease it is, it ain't going on a Nuclear Submarine.
Kevin
Retired, Fulltime RV'er, 1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler, 2019 Polaris Ranger
Bob, the Yorkie Terrier helping me prospect til the money runs out
JIMNLIN
just a dab of high pressure red grease in the jaw contact area just like a OTR rig
christopherglen
My basic rule for anything that rubs: If it is rusty, paint it. If it is shiny, lube it. I use White lithium grease on kingpins, hitch balls, equalizers, slide parts (not the rams), pretty much all zerc's...
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
stickdog
I use white lithium spray on the king pin as recommended by the hitch manufacture and grease the fittings on the hitch as recommended. Also use the teflon disk on the bearing surface it stays cleaner that way and so do I.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
lc0338
White lithium grease is the best "metal to metal" lubricant and I understand it is good for "metal to plastic" as well. You can get it in aerosol spray can. I spray my gooseneck ball often.
Old-Biscuit
I use the teflon lube plate so that I don't have to grease pin box plate or 5th wheel hitch plate.
But I do put a film of grease on king pin, hitch jaws and all pivot points/metal to metal contact within hitch.
On king pin/hitch jaws....a green grease. Have no idea what it is. Friend gave me a large tube few years ago. Goes a long way...thin film and lasts
Pivots/contact points...dry spray on graphite lube
TXiceman
WD40 is not a lubricant in any way shape or form. WD is for water dispersant.
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
shadows4
Paul Clancy wrote:
Red bearing grease.
X2
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
Paul_Clancy
Red bearing grease.
