Towing a 5'r with a 4X4
GertiesTravels
We are looking for a new (to us)TV and would like to go with a 2500 4x4 crew cab short bed to tow our Cruiser. We are looking in the 2008 to 2011 range and got a Big shock at the height of the rails on these trucks! Fords seem to run about 57 inches and Chevy/GMC or Dodge are hovering in the 60" range. Problem is our 5'r is 58" under the nose and I have already done the axle flip.Surely people must be hauling 5'rs with 4x4's, how is it done?
Any advise would be surely appreciated.
Thanks
Jim D
1991 Chevy Western Hauler 454 engine - RV cam, Headers, Dual Flowmasters, K&N 100 Gall Aux Gas tank
2004 29' Crossroads Cruiser 5th wheel
4 Interstate GC Batteries + WM Caps
2 daughters & 1 Miniature Dachshund adventurer.
28 REPLIES 28
garyp4951
FWIW when I towed a little nose high I never had chucking, but with new hitch being set lower, and towing level, I've noticed some chucking on rough roads.
Shepherd
The bed rails are higher. I had a level kit installed on the tow vehicle.:C
2018 Ram 3500 CC aisin/4.10
2014 Rushmore Monticello
oldbeek
The newer trucks are getting taller. Install a flat bed and flip your springs back to stock. The whole rig will tow better with lots of bed clearance.
1994 27sl Alpenlite with many mods, 2001 Dodge Cummins 2x4 3.54 Auto trans built shift kit and 2nd gear lock up mod. Mojave Green billet, triple disc low stall torque converter. Gauges and raptor 3/8inch fuel system. 12.5 mpg avg
waltbennett
kroghville wrote:
WE pull a Montana with a 2011 F-350 SRW and it tows level. No Problem!!!
Ditto (but older truck!)
'06 F350 TD, Softopper, airbags, AeroShield, coolant filter
'10 3665RE Hickory edition, wetbolts, Firestone LTs, Trimetric Battery Monitor, 4x100w panels & Morningstar TS-45, still tweeking.
Beaker
Don't know about now but when I bought mine there was no difference to speak of between 4x2 and 4x4.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
Poppy_s_5th_Whe
Shadow_Grey wrote:
The whole deal before was to get the trailer as level as possable because the axles were supported independantly to the frame. If too low or too high in the front the trailer would transfer more of weight to the front or rear tire possably overloading them. Today most all trailers have a equialized suspension meaning there is a pivot point that the rear of the front spring and the front of the rear spring are tied together. This allows the front tire and the rear tire to carry the load equally if the trailer is not riding level.
That being said you still need bed rail to trailer clearance and as said in the previous post, running nose high seems to be very common among us with late model trucks. If your camper has the equalizer on the suspension don't worry about the atitude (within reason) of the camper connected to the truck.
This is an excellent post. Within reason .... obviously riding 6 inches high is not likely to equalize but great information.
Paul "Poppy" Cervone
2016 GMC Summit White Denali 3500HD SRW CC/SB
2015 Grand Design Reflection 337 RLS
RCMAN46
BB_TX wrote:
Many of the 5ers do ride a little nose high, including mine. But, at least in my case, it is not enough to be a concern. A couple inches nose high is not going to shift any significant amount of weight to the rear axle.
Have you ever weighed the axles on your trailer?
One poster said he tows 4 inches nose high. If he were to do the scales I am sure he will be in for a big surprise.
Shadow_Grey
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
Uppercrust
With our truck 4x4 F250 2012, cruiser 345rf, it is no problem, we did have to install airbags cause of a little squat. When we hook it up it has enough clearance.
2012 F250 CC,FX4, Metallic blue/Silver
2012 Cruiser Patriot 345RF 🙂 campers mom, dad
19 yr. old son
22 yr. old daughter
Diesel R.I.P.
Lady lab mix 16 R.I.P
Daisy beagle/collie
Misty shepard/husky
Camper's Have Smore Fun
14.5 Rallies
sleepovers 3
klr650goldwing
TVs are higher than they used to be. We have a 2004 Ford F350 4X4 and our Cruiser tows level.
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
Halmfamily
We have an'08 GMC Sierra and tow our fiver with 5" of bed clearance and 4" nose high. As others have said your truck will squat once hooked up. Good luck
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
Dandy_Dan
Jim, I tow our 5er with the Dodge in my signature. It has stock suspension on 16" rubber and the 5er is also on 16" rubber. I adjusted the hitch height a touch and haul level. Hopes this may shed a little light. Good Luck and Happy Camping.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
GertiesTravels
jerem0621 wrote:
OP I like that western hauler you have there! Those are getting rare!
Yes, and it is a good truck. Unfortunately it has spent to much of its life in the rust belt and has more issues than I can fix since they replaced my back last year. I no longer bend or lift so maintaining "Galloping Gertie" is not an option any more. Kind of hate to see the old girl go.
GertiesTravels
