โFeb-18-2015 03:29 AM
โFeb-18-2015 04:22 PM
โFeb-18-2015 03:15 PM
โFeb-18-2015 02:37 PM
โFeb-18-2015 10:04 AM
โFeb-18-2015 09:41 AM
up2nogood wrote:C-Bears wrote:SCCamper wrote:
Hi all, new member here.
My Dad has a 2014 Dodge 2500 4x4 he would like to use to tow a 5th wheel. The issue is that the truck be is 60-61" high which I believe is 6-7" too tall for most fifth wheel campers.
Thanks
My F350 measures 58" from the ground to the top of the bed rails. I am surprised that a 3/4 ton Dodge would sit 2 - 3" higher, so does he have some type of lift kit or oversize tires on his truck?
If the Dodge is "jacked" or has some type of huge aftermarket tires then I would correct those issues. Otherwise, if the truck is generally stock then you probably don't have anything to worry about even if it is 61" high. As others have stated you can make adjustments to hitches or adjustments to pin boxes. Either way you are not going to be 6" or 7" too high for a 5th wheel, or at least nothing produced in the last 10 years.
I have a stock 2014 Ram 3500 ,and it sits 59.5 inches to the top of the tailgate, a little shorter then the op's 2500 . Stock tires rims etc etc
I own a 2008 Montana fifth wheel ,with the axles above the springs, my pin box is a high as it can go , and the hitch is as low as I dare go, and I am still around 3-4 inches too tall. There is nothing else I can do short of lowering the Stock truck or raising the fifth wheel more.
Maybe the newer fifth wheels will be okay, but my 7 year old fifth wheel is not.These new trucks are just too high in the rear. My previous truck with same fifth wheel was borderline high ( 1999 Superduty 350 )
โFeb-18-2015 08:41 AM
MFL wrote:
Most newer mid sized FWs will have a similar pin box height. I think most newer, will also have the springs on top of axle.
I think even with the coils, the Ram will squat some. I tow my FW a little nose high, not a big deal. The larger FWs with taller tires, and more hitch weight, are the ones you see towing nice and level.
If you can get 6"s bed rail clearance, even if you need to be 1-2 inches nose high, it will work.
Jerry
โFeb-18-2015 08:02 AM
โFeb-18-2015 07:51 AM
Thanks
โFeb-18-2015 07:28 AM
โFeb-18-2015 07:22 AM
โFeb-18-2015 05:46 AM
โFeb-18-2015 05:43 AM
SCCamper wrote:no sir I had no problems at all hight or other wise I have an older fifth wheel so its no as tall as a lot of the newer ones. also I have been reading where a lot of the newer rigs come with the axles already under the springs have you had a look under there yet?tn terry t wrote:
dexter makes a kit to put the axles under the springs in which will give about four inches I have put two of these kits on with no problems also you could have a sub frame built. I've seen 2x4 and 2x6 square tubing to build these sub frames
Terry, did you have any problems with the height clearance (low bridges, tree limbs in campgrounds) or did you notice any problems with stability in crosswinds on the interstate?
Thanks-Brian
โFeb-18-2015 05:42 AM
SCCamper wrote:
My Dad has a 2014 Dodge 2500 4x4 he would like to use to tow a 5th wheel. The issue is that the truck be is 60-61" high which I believe is 6-7" too tall for most fifth wheel campers. There is no easy way to lower the truck.
โFeb-18-2015 05:35 AM
Thanks
โFeb-18-2015 05:20 AM
