Viair 12 volt portable air compressor
grampscamper
I'm looking at purchasing a 12 volt portable air compressor. Our 5th wheel is in storage several miles from our home. When I go to pick it up after sitting for long periods the tires are down a few pounds. Now I carry a portable air tank with me but I can only add a few pounds to each tire. When we travel I carry a 120 volt compressor. I would like to purchase a 12 volt compressor so I can use it anywhere.
I'm presently looking at the Viair models 400P, 400P auto, 400PRV and 450P auto. I will be using it for my F250 & 5th wheel. The tire pressure in our 5th wheel is 80 psi. I'm leaning toward the 400PRV or 450P auto. The 400 series has a 33% duty cycle and the 450 100%. The price is the same for either.
Are they good compressors? Would 33% duty cycle be sufficient?
2019 Grand Design Reflection 230RL
2020 Ford F250 Lariat CC SB 4X4 6.7 B&W Companion RVK3300
15 REPLIES 15
grampscamper
bigdon68 wrote:
I have had a 200psi Viair system on my F350 for the fast 3 years. It is great. You can take a look at my install under MY PICTURES. We installed (2) 480 Viair compressors, (2) 5 gallon tanks. There is a Schrader air valve on each side of the truck. For kicks I installed a set of Shocker train horns -- for those people who insist on pulling in front of you. I got the entire setup at Hornblasters. It is great for air tools, tires, air hydraulic jack and our air hitch.
Enjoy the road. We do.
bigdon68
Nice setup. You did an amazing job.
I also saw the pictures of the tire blowout. Another reason to keep an eye on my tires. I now have a TPMS installed on our 5th wheel. The portable compressor will be a great addition.
Have to have all the toys.
bigdon68
bigdon68
2017 F450 Lariat Shadow Black / Magnetic, LB, 6.7, Chrome Pkg. TS3 Air Hitch, Retrax, 55 Gal.Aux.Tank
2017 DRV Mobile Suites,induction cooktop, solar, f/b paint, MorRyde IS, 17.5" Tires,residential frig, 3" riser, MorRyde Steps
MY PICTURES
grampscamper
Ordered the Viair 400P-RV automatic from Amazon this morning. I went with this model for the following reasons.
Portable
Can use it anywhere I have a 12 volt battery
More volume than 450P
Positive reviews
Quick connect air gun
2 quick connect air hoses
Carrying case
Inline gauge
I presently own a cheap 12 volt compressor that plugs into a 12 volt accessory outlet. It is very slow and doesn't have a long enough cord to reach the 5th wheel easily. I have also carried portable air tanks but find they have limited capacity.
It was a tough decision. The Viair is pricey but I believe you get what you pay for.
Thanks for all the replies.
soos
LANShark42 wrote:
I'm new at this and trying to learn. (We don't even have our TT home yet or a TV to pull it. lol)
Why do you need the portable when you carry a 120V? And do you use the 120v much? For what purposes? Just curious. We are trying to get an inventory together of what to take with us.
Thanks,
Michael
And some of us have 10 tires or more, plus the air hitch and the airsprings on the truck that need adjustment.
Sue
soos-ontheroad.blogspot.com
Fulltiming since 2009
2012 Mobile Suites 36 TKSB4 pulled by a
2011 Ford F450
2005 Lance 1181 TC- our Vacation Home
Goostoff
Viar is probably the best 12V portable compressor you will get. With that being said, another option is the Slime brand from Wal-Mart. I bought the best one they had a few years ago to keep in my jeep for off road trips. It will pump up my 35" tires from 6psi to 30psi in just a few minutes time. I love it and it was only like $54 and comes with a nice durable bag. I also have my 120V compressor in the basement of the 5er. As stated before you will become the hit with the kids at the park. They always have bike tires and basketballs to be pumped up.
Another option is to just put in a power converter or inverter what ever one goes from 12V to 120V and just run your 120V off the battery after you get hooked up of coarse. 🙂
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Dtank
Thanks,
Michael
And another alternative -
Research Power Tank CO2 systems
You can set up your own for about 1/2 the cost.
Very popular with off-roaders as well as RVers.
No power necessary, no noise, no mechanical (failure) problems - gets it done "right now"..;)
wilber1
I went with the 400P and haven't been dissapointed. Even though it doesn't have the 450's 100% duty cycle, it is smaller, lighter and has a higher cfm output.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
grampscamper
Thanks,
Michael
Where my 5th wheel is stored there isn't access to 120 volts. I like the idea of being able to fill my tires anywhere, anytime. Not a problem with 2 batteries in my truck and one in the 5th wheel. This looks like a very portable unit.
Michael, I don't use the 120 volt compressor often but like to be prepared for anything. The first weekend out with our 5th wheel I picked up a screw. Had to add 20 lbs. when I got home. Now I carry a compressor and check my tires frequently. I also use my 120 volt compressor for winterizing (blowing out the lines). It's a 3 gallon with adjustable air pressure.
I also carry two 20 ton bottle jacks & jack stands.
Thanks for the replies.
Bob_Olallawa
Thanks,
Michael
Nice to have a good 12 volt unit when not near a 120 volt system. Uses, when you need to add air to......
Welcome to my home, that door you just broke down was there for your protection not mine.
LANShark42
Thanks,
Michael
2015 F250XLT 6.2l V8, 4x4, 10KEqual-i-zer Hitch
2015 Coachmen Catalina 273BH
2014 Akita (named Mizuki)
Old-Biscuit
I've had a Viair 400 for over 7 yrs.
Used it for 5vr tires (110#) and truck tires (80#).
Great 12V DC compressor.
ScottG
Yes, Viar makes some of the best small compressors out there.
RoyB
I have been using a like 12VDC portable unit for years back in my JEEP TRAIL days of the 60s up to present time with my OFF-ROAD POPUP trailer...
This is the Q Industries portable MV50 12VDC 150 PSI Air Compressor available from AMAZON. It fits in its nice carry bag under my truck back seat. I usually sit this on my truck tailgate and hook into the trailer batteries and then I can use the provided long air coil hose to walk around the trailer and tires...
I also use this air compressor along with the CAMCO 36153 Blow Out Adapter to blow out my water lines for winterizing. Being TANKLESS it takes more time to build up air compressor which is ideal for blowing out water lines.
Perfect setup for me and my OFF-ROAD POPUP trailer.
I got a new one in 2008 from AMAZON when I started pulling my OFF-ROAD POPUP trailer.
You become king of the campground with all the kids and their bicycle when they find out you have a portable air compressor...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
WyoTraveler
I have had the Vair 450P for 2 years and I like it. I like the auto feature.
