What did you do to your Toy Hauler today???
Rich_Panganiban
This is always a fun thread to watch so I thought I would start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
2,288 REPLIES 2,288
sin_cal_hd
We will be repacking bearings on my parents tomorrow.
2015 2500 Ram Mega Cab 4x4
2017 Wolf pack 325
Wife and 2 little boys
2 golden retriever pups
RUFFSTUFF
Bedlam wrote:
It must be the season to repack bearings. I just did four hubs and replaced two tires.
I need to find a "how-to" on repacking bearings...
2014 KZ Inferno 3712T
2015 Ford F350 DRW Platinum 6.7L
2010 Ford F250 Crew Cab 6.4L
RUFFSTUFF
My generator wouldn't start, so I spent a good deal of time troubleshooting, testing the fuel system and trying to clean the carb. Nothing worked. So I replaced the fuel pump/filter, nope, wouldn't start. Then I replaced the air filter and the carb. Yeah, it was the carb. Now it runs like a champ.
Bedlam
Moderator
Moderator
ependydad
Topped up all of the tires on the trailer and truck.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
nayther
installed 300 watts solar
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
lincster
Repacked all bearings.
Greased suspension.
Fixed crack in fuel station tank.
New Propane hose.
Adjusted brakes.
Getting ready for dune season!!!!!!
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
sin_cal_hd
Repacked bearings
Re-welded a brace after a tire blowout damaged it.
Installed new trim around the ramp in both sides.
2017 Wolf pack 325
eDUBz
Had shade pro come out and install new awning
LBZ - Stealth TH - RZR 900 4 - Honda 450X - Paddleboarder - Fisherman - Kayaker
rovyart
I installed a newfifth wheel hitch and did some cleaning on our cabinets today.
fifth wheel
RTBabich
1L243 wrote:
.... So I orderd a 7 Way 8' harness with junction box that is color coded. ....
I love those junction boxes, it makes trouble shooting wiring a lot easier.
For trailers with 4 electric brakes the wire gauge size is sometimes just adequate.
Ours ran one wire from the 7 way to the LF brake, on to the LR brake, crossed over to the RR then ended at the RF.
I ran a larger gauge wire for each brake from the post in the junction box to each brake.
Now if I want to test a particular brake I can pull its' wire for testing and I know each brake is getting a good voltage.
2009 Weekend Warrior, FB2100, 23ft, 7.5k, Maxxis ST225/75R15, Dexter EZ Flex, Equalizer 10k
MartyMoose
"Dumped vegetable oil into the tanks to try to loosen up the dump valves."
First I've seen this.....work? Mine is sticky which makes me nervous....ha
Thanks
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
Flashman
I moved my rear scissors jacks forward on the frame a couple of feet - to give me better clearance in the rear when going through dips or over bumps.
1320Fastback
Was last weekend but fixed a propane leak where road debris cracked a fitting under the trailer, rotated the tires, lubed the bearings and adjusted the brakes. We just got back from a 5,200 mile trip and are leaving again soon for about another 1,000 round trip.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
