What truck to tow my tow hauler?
fergie1111
So have a 2011 Ford F150 with the ecoboost V-6 engine that is supposed to tow 11,500 LBS. It does but wont pull at elevation and high temps without overheating. Ford has no fix for this problem as of yet and has been working on this for the past year. So im in the market for a newer truck. I will only be using the truck to tow my 22' toy hauler. the hauler weighs 5200 dry and probably 9000lbs at the most if its fully loaded. My ford is all over the road when its windy. My buddy towed my camper with his Dodge 3500 and I couldnt even tell it was back there. Im open to all suggestion about a new truck. Diesel or gas? Dodge 1500 or 2500, Ford 250 gas or diesel? Chevy 2500 gas or diesel?
58 REPLIES 58
lincster
64thunderbolt wrote:
the one I was talking about hauls a 43' goose neck all over the country. He has a moving co. And will put 30K on that trailer.
Well, that isn't a toy hauler is it? This is a toy hauler section, so that is what we are talking about.
Is this the same guy that you said blows XPS Rib tires in another post???? 30K on that trailer, yeah, E rated tires are WAYYYYYY overloaded if that is the case. :S
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
64thunderbolt
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
lincster
My new truck doesn't know what a hill is.
My buddy has a 2008 F450 with the 4.88 gears and towing a big hauler like mine. He says my truck will out tow his.
Since 2011 Superduties came out, you don't need a F450 anymore.
F350 will handle any big toy hauler out there.
The only difference between newer F450's and F350's is 3000lbs more in GCWR. GVWR is the same between both trucks.
I have a payment, but I also know I am within all of the tow ratings of my truck. 🙂 That is important to me.
Lincsters Rail
64thunderbolt
musclecarsKC wrote:
linster and 64thunderbolt. Thank you for your insight. linster, I you are right. We might have to go the route of 64thunderbolt for a while until we find what we really want. Looking a F550's would love a Topkick or Kodiac but haven't found any around this area to check out.
My truck tows very well. Some new ones will do better but mine has been paid for since the day I bought it.
If you go the 550 or the others you mentioned will the drivetrain keep up with the added wgt? An F450 would do just fine. A friend has an F450 with 4.88's and won't break any speed records but doesn't know what a hill is. It's a 6.4 with a 200 hp tow tune.
Glen
Truma tankless WH
2011 RZR 900xp
musclecarsKC
2008 All American Sport 40"
1999 F350 Lariat 7.3L power stroke diesel crew cab dually
Life long campers
lincster
musclecarsKC wrote:
I'm looking for some of you with really big TH's and what you are using to tow. We have a 40 ft. All American Sport 15K dry weight. We have a 1999 F350 dually diesel. We had a little transmission over heating problem a few weeks ago. We've been told the truck is big enough and told we need a bigger truck. Anybody beef up the tranny or add airbags to the rear suspension? Any experience and knowledge would be great!
I tow my 41' Weekend Warrior with a 2012 F350 Dually.
My GCWR is 30,000lbs. Fully loaded, I am at 27,000lbs going down the road.
You need more truck. GCWR on your truck is 20,000 lbs. Truck probably weighs around 8000lbs. So unless your trailer is 12000lbs going down the road, you are over your GCWR.
Lincsters Rail
64thunderbolt
My F350 is fine with that wgt. The air bags were the best investment. More stable, MUCH better ride & easier to hook & drop.
Add a trucool cooler and a JW or BTS valvebody to your trans and it will live.
Glen
Truma tankless WH
2011 RZR 900xp
souraider
fergie1111,
Any of the big-3 trucks will do the job quite well for you. I am partial to Ford, but would recommend looking around your Dodge dealers for any leftover 2012 models. The reason being is this was the last of big-3 three that did not have the DEF tank. DEF stands for "diesel emissions fluid" and it is an additional fluid (urea) that has to be added at oil changes per emission regulations. It is not a huge deal, but it is one more thing to pay for and monitor over the life of ownership.
'17 F350 STX 6.7
'15 Stealth WA2313
'20 Can Am Maverick Sport 1000R
Big_Ray
kjk66ss wrote:
three letters for you " LBZ"!!
or CTD :B
2011 Rockwood 8314BSS Signature
2013 Ram 3500 Big Horn 4X4 Crew Cab DRW with the 6.7 Cummins
mpierce
I would add an additional oil cooler on the truck. Otherwise, I think you are fine.
musclecarsKC
Yes, our F350 does have a transmission cooler. Just upgraded it (they said when the transmission was replaced a few years ago they should have upgraded then but didn't). Somebody also suggested adding another cooler.
Hate to buy a new pick up when this one is paid off. We like those words "paid off".
Life long campers
Ric_Flair
Does your 99 F350 have a transmission cooler?
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
musclecarsKC
Life long campers
pronstar
Ric Flair wrote:
Would that be two 1.0 L EcoBoost I-3's run in series?
Or something like this old ford 300 ci twin turbo frankenmotor?
If it's the latter, hell yes
The judges will accept either answer :B
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
Ric_Flair
pronstar wrote:
Ric Flair wrote:
I wouldn't tow 5 1/2 tons of payload for any distance with a V6, turbocharged or not.
But if those 6 cylinders are arranged in a straight line, that's alright 😉
