Appalling sound from Onan QG 2800
wincrasher65
I ordered a resonator and a downpipe to see if I could quiet the noise a bit.
Without anything running inside, except the fridge I get this at about 10 feet:
With the resonator:
Without resonator, but with down pipe:
Generator shut off, quiet shop:
The tone is much more pleasant with the resonator. The down pipe also mods the tone, but not that much.
2016 Winnebago Travato 59K, 2017 Allegro 32SA
Follow my blog: www.wincrasher.blogspot.com
Our Facebook group is: Class B Camper Vans
17 REPLIES 17
Arizona_Kid
wincrasher65 wrote:
Good question. I suspect Onan's are cheap to the RV manufacturers - especially on volume.
The Honda 2000 would be good as a built-in, as it's already can be fueled with a gravity fed tank - like an outboard boat motor. The 3000 cannot be fueled the same way, so would need some modification. Across the board, the inverter type generators are quieter. Why the onan is so unnecessarily loud is beyond me - mostly because they have no insulated enclosure or muffler on the exhaust.
They have an enclosed muffler.
The Onan can be make quieter. Resonator, exhaust hanger mounts, thicker rubber washers on the mounts. Make sure everything is tight, and not causing other things to vibrate.
stan909
I urge you to try a baffle. It works in recording studios. I realize it is not technically lowering the db output but it will diffuse the sound to the ground and if you are camped on dirt or better yet grass there will be an appreciable difference. Concrete is the worst reflective surface as far as sound deadening. Asphalt would be next but baffles could help. I too hate to run my generator for the same reasons as you and applaud your efforts.
Handbasket
SkiMore wrote:
Is the Honda really less reliable/durable than the Onan? I understand why the cheap contractor grade generators are loud - they are cheap. The Onan isn't cheap. How can Honda and Yamaha make something so much quieter and why aren't they in the business of making a built in model? What is it that I don't understand?
As far as Honda reliability, the comments I've read and made are based on the older & discontinued 3010 & 4010 (think those #'s are right) that are made for RV installation... water cooled, constant-speed, heavy & complex, seem to be as noisy as an Onan.
Why no one builds a a B-sized quiet inverter unit for RV installation? Probably because it A) a very limited market with high liability potential, and B) it's a very harsh environment (exposed underfloor mount). Probably more reasons, too.
Is it practical to DIY modify a quiet portable for installed use? Depends on your engineering skills and risk aversion. Consequences for a less-than-perfect installation can be lethal.
Jim, "In the real world there are no rewards of punishments, only consequences."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
wincrasher65
SkiMore
BudJ
Hi gerrym51,
An increase of 3 db requires twice the power but not double the sound. It is somewhat subjective, but double the sound is about a 10 db increase that requires 10 times the power. Twice the power for each 3 db increase.
The Onan is LOUD, the honda is quiet.
Bud
gerrym51
SkiMore wrote:
Isn't the Honda 3000 generator rated at something like 55db? How can they be so much quieter?
every 3 decibles more is DOUBLE the sound. 55 to onans 70 is at least 5 times louder
wincrasher65
1775 wrote:
What readings do you get inside the RV with the generator running with and without the add ons?
I will check this weekend when I'm home. Not too concerned with interior noise though. More concerned with disturbing other campers.
wincrasher65
Much less - closer to 50 db. I have one and it's an amazing piece of equipment. Too bad it's too heavy to carry with me (159 lbs.)
Too bad these units can't be integrated into a B van.
1775
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
loggenrock
Present-day Hondas are "Inverter" generators - actually create power differently (in the Onan the engine turns a standard generator winding. Inverters have magic electron powder or similar inside...). Second is durability. Onans can run for thousands of hours - not typically done with Hondas, etc. Still wish my green machine ran quieter!!! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
SkiMore
wsfurrie
Depending on your phone it will not work for very loud sounds. The mike limits it. Mine pegs at 80db. I have resigned myself to parking a long way away from others if possible, or park next to a running big rig.:)
Wayne, 05 PW Excel
Wayne
IAMICHABOD
path1 wrote:
(Sorry off topic but I need help)
Is that tool expensive?
I need one for my wife that talks to me same time looking out the window the other way and complains I don't listen to her.
YA, Because I can't hear her...that tool would provide proof.
I put one on my phone for free from the Google Play store. It works just as well.
SOUND METER
For pretty much the same reasons.............:B
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
