โNov-01-2014 11:56 AM
โNov-03-2014 09:59 PM
โNov-03-2014 03:40 PM
โNov-03-2014 01:13 PM
โNov-03-2014 01:07 PM
Grandpere wrote:Y-Guy wrote:
Scott you are completely wrong. From the EPA, "Antifreeze is toxic to humans and animals. Waste antifreeze contains heavy metals such as lead, cadmium, and chromium in high enough levels to potentially make it a regulated hazardous waste, so most states strictly regulate antifreeze disposal."
Do you want that stuff in your water system or environment? It is totally irresponsible to dump any amount down the sewer.
I did not know that, that is why I asked. I will be using RV antifreeze and hope for the best.
โNov-03-2014 12:43 PM
Dale.Traveling wrote:
A quiet, sensible voice in the crowd.
Another option would be to use a vacuum cleaner, reversing the hose, and blow out the traps. Dewater the coach, potable and waste.
Now a new question - are the chemicals sold to hide tank orders safe for the environment?
โNov-03-2014 05:07 AM
โNov-03-2014 02:59 AM
โNov-02-2014 09:03 AM
naturist wrote:
$12-$15 a gallon vs. $2-$4 a gallon . . . seems like a no-brainer to me.
โNov-01-2014 10:22 PM
โNov-01-2014 06:59 PM
โNov-01-2014 06:40 PM
RoadAbode wrote:
As we age we learn that the way we do some jobs change. We learn new ways to do old things. In the end, using the right product will be better for all.
So let's learn about why automotive antifreeze should not be put into our sewer systems or watersheds:
From the EPAAntifreeze is toxic to humans and animals. Waste antifreeze contains heavy metals such as lead, cadmium, and chromium in high enough levels to potentially make it a regulated hazardous waste, so most states strictly regulate antifreeze disposal. Antifreeze generators and state and local programs should not dump spent antifreeze on land or discharge it into a sanitary sewer, storm drain, ditch, dry well, or septic system; dumping antifreeze can cause serious water quality problems and might harm people, pets, or wildlife.
Is wastewater treated? Yes, it is treated in order to reduce the hazards of the infectious agents that are in it. Waste water is not treated with the intention of neutralizing industrial chemicals, and in fact, disposal of industrial chemicals will frequently cause harm to the equipment that is used to treat waste water.
It is very naive (and dangerous) to assume that all of our waste water treatment plants are set up to neutralize any substance that someone chooses to dump into a septic or sewer system.
โNov-01-2014 06:33 PM
Dr Quick wrote:
Since RV antifreeze is about 1/3 the cost of Vehicle antifreeze, WHY would even consider using it?
โNov-01-2014 06:00 PM
โNov-01-2014 05:14 PM
