Black tank odor
senior-cit
Anybody know of a home-made deoderizer to use in the black tank rather than a store bought one? We ran out whill dry camping and would like to see if there is a back-up.
11 REPLIES 11
Lobstah
Glad it's resolved...and thanks for posting the end of the story ๐Ÿ™‚
Jim
2005 Pace Arrow 36D
Very Understanding Wife
1 Boxer ๐Ÿ˜ž
3 Maine Coon cats
senior-cit
Thanks for the responses. I found out what was the reason for black tank odor. The electric flush toilet in the rear bathroom was not leaving water in the stool and the odor was coming out of the stool, especialy when moving.
senior-cit
Executive45
Water water water.....Dennis
doxiemom11
Lots of water and never use any chemicals. Never any odor except right when flushing as it gets full. I would also never use bleach. Bleach used on a continuous basis will damage any seals (think valve seals, toilet bowl seal).
Blaster_Man
Old-Biscuit wrote:
lanerd wrote:
If you have black tank "odor" inside your mh.....something is wrong. Either your vent is plugged or the seal on your toilet is not sealing properly. If you experience the odor right after you flush, that is normal. Be sure to turn off the vent fan when doing this as it will pull the odors right out of the tank and up the toilet. If you have a small leak (drip) in any of your connections at the drain gate or sewer hose, will also cause an odor that can seep into the interior of the coach.
Adding chemicals to mask the odor is not solving the problem. A properly operating and sealed black tank system will NOT produce an odor under normal conditions.
Ding, ding, ding......winner!
That's for sure!
2014 American Eagle
Old-Biscuit
lanerd
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
RckyMtnVia
Another fan of the Geo Method. Works very well.
2022 Forester MBS 2401B
brirene
Copied from the Geo Method (Charles Bruni). I would recommend the entire process when you're able, but this may address your current circumstance:
"Occasionally, I pour a half gallon of liquid bleach into each tank to deodorize, sanitize and disinfect them. I add the bleach when the tank is about half full, and then continue to use the tank normally until it is full and ready to dump. I no longer use the blue toilet chemical because it isn't necessary. I have no odors coming from my black water tank. The chlorine bleach kills the bacteria, which is primarily responsible for waste water tank odor. Generic brand liquid bleach is cheap and very effective."
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
gbopp
Some use the Geo Method or something similar. It works for me.
Others use just water, nothing else.
