Jan-26-2021 06:50 PM
Feb-22-2021 11:34 AM
Feb-19-2021 08:07 PM
Feb-02-2021 12:24 PM
Feb-01-2021 01:40 PM
T-Rex wrote:
When I bought this 2007 RV in 2015, it was 8 years old, but had only 9,000 miles on it. With so few miles at the time, my guess is that the prior owner never cleaned the K&N filter, and therefore, over-oiling of the filter isn't causing MAF sensor problems.
Feb-01-2021 01:38 PM
Jan-28-2021 08:17 AM
Beaker wrote:I thought the OP has a code tester , he has been erasing the codes, its a recurring problem with that 2195 code.
Recent experience with Dodge dealer.
1999 dakota cel with code showing 02 sensor.
Sensor replaced, code still showing.
Dealer said pcm.
Changed pcm, code still showing.
Dealer said bad pcm. Was replaced. Code still showing, said bad pcm.
Pcm(remanufactured) replaced. Code still showing.
After spending $500 at dealer they would not pursue anymore.
Indepedent shop at $50/hour. Gave them 2 hours at no risk.
They found broken wire.
I won't talk about the A/C the dealer couldn't fix for 2 years.
Independent dealer fixed in 20 minutes for $20 dollars.
Not saying this is your problem.
Just saying that mechanics are trained to follow a,b,c and cannot find problems that do not follow the "rule".
Forgot to say dodge dealer mechanic was "certified master mechanic"
Jan-27-2021 08:00 PM
Jan-27-2021 07:56 PM
BurbMan wrote:
Apply logic here: The MAF measures incoming air and the then PCM pulses the fuel injectors to dispense the right amount of fuel. If the O2 sensor says the mixture is always too lean, that means too little fuel or too much air. If too much air, then either the MAF is sending the wrong reading, or air is getting in somewhere after the MAF.
The lean code is also the symptom, fix the rough idle and the code will go away. Since the O2 sensor was already changed it's likely not that.
1. Get some MAF cleaner from the auto parts store and clean the MAF. DO NOT use any other chemical to clean the MAF.
2. Replace the air filter.
3. Check all vacuum lines for leaks, the V-10 has the known issue Grit Dog mentioned, the hove from the PCV melting.
4. Check for air leaks, be sure all bolts are tight to throttle body and intake manifold.
5. Check air intake tube after the MAF for cracks, etc.
A lean condition can also be caused by too little fuel, so it's possible one or more injectors on bank 1 are clogged or defective, but this is much less likely at this mileage that an air leak.
Jan-27-2021 07:36 PM
rjstractor wrote:T-Rex wrote:
I can (and have) changed the oil. I've also recently changed (actually, reconditioned, the K&N air filter). This is pretty much the extent of anything I've ever done on an engine; however, with detailed instructions, I'm ready and willing to expand my meager experience.
The K&N filter might have something to do with your issues. From what I understand, even slightly over-oiling the filter can lead to a fouled MAF sensor, which sounds like it may be one of the things contributing to your CEL codes.
Jan-27-2021 07:35 PM
Jan-27-2021 05:37 PM
Jan-27-2021 05:36 PM
T-Rex wrote:K&N filters are known to cause problems with MAF sensors. As mentioned, clean it !
Jan-27-2021 05:34 PM
Jan-27-2021 11:42 AM
T-Rex wrote:
When you say that I should spray the contacts, are you referring to spraying the electrical connection that I disconnect in order to clean or replace the sensors (eg. MAF sensor)?
