Diamond Shield removal
fuzzyface
Well -- after much reading on this forum and others, my wife and I started scraping the diamond shield******off the front of our motorhome. The heat gun simply made a gooey mess of things, and peeling it off without the heat gun resulted in very small pieces coming off. We did clear the small area under the entrance door to the motorhome, but still (after about 4 hours work) have 90% of the nose of the vehicle to do. Goof off does work well on the residual glue, but the film itself comes off in very small pieces. We need help, advise, or a BOMB...........
Linda and Mike Kruzin' in a Kountry Star
29 REPLIES 29
Big_Katuna
Mine went bad year 6 out of warranty. I think humid conditions get the mildew growing.
I got the lower front off pretty easy. The upper part above the windshield is coming off in dime size pieces.
My Kharma ran over my Dogma.
67Cutlass
Since my last post in November 2013, I've discovered not only has my DS started to peal. It has also started to 'shatter'. Very fine cracks have started to appear. It looks like very fine shattered glass.
Hum - not to bad for only being applied for about 2 1/2 years. :R
The plan is still have a bra made on our trip to the Keys this January.
2012 Phaeton 40QBH
2015 Jeep Cherokee
SMI Air Force One
Retired USAF - CEVG and AFTAC
Member of Tiffin RV Network Forum
BobGed
Just keep in mind this is like a lot of other things. You're going to hear more from folks with complaints than you will from those that are having a positive experience with a product.
I had Diamond Shield on my coach for six years, and except for a ding that I put in it with a ladder, it looked great.
I did take care of it by keeping it waxed and removing bugs after each day's drive with a soft pad and water only.
2017 Tiffin Phaeton 40QBH
2014 Jeep Cherokee Limited
StephJohn2010
The Diamond Shield company tells you to keep pristine care of it and it won't be a problem... Not True! I have and black streaks are already starting on my 2012. Motorhome companies need to seriously stop putting this stuff on.
John & Steph
2012 Fleetwood Discovery 40x (35,000 miles)
380 HP Cummins with an Allison Transmission - Freightliner Chassis
2015 Jeep Cherokee Limited Active Drive II
smlranger
I am in the process of removing my DS now. I am traveling and left my heat gun at home so have been taking advantage of the sun. I let the sun warm it and it pulls off easier than I had expected. Mostly, I am getting large pieces off.
I am using mineral spirits to soften the adhesive, I scrape most of it off with plastic razor blades, then use lacquer thinner to get off the remaining glue. The paint is pristine.
I am now at Myrtle Beach for two weeks and plan to use the AM sun to finish up.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
charming
Ouch! Is all I can say. We have Diamond Shield on our 2008 R-Vision and it looks awful! The part over the cab is coated in tree sap or something - brown streaks all over. We have a call in to Diamond Shield but from reading this I'm wondering if it is a lost cause?
Looking forward to new adventures and new friends.
JTHarley
Did mine while wintering in Floridaโ€ฆโ€ฆ.used steam, heat gun and the stuff they sent me to remove it. 2 people working 6 hours each day and it took almost 4 days to get it all off. I will NEVER use this stuff again.
Jim , MJ & Spirit of Sambuca Bear
2015 Dynamax DQ320XL
Jeep Sahara Toad
JTHarley
Jeep Sahara Toad
Nomadac
Quote: Diamond Shield tech used a wallpaper steamer to heat and soften the film then cleaned up behind it with Xylene. The steam will not over heat the film but soften the glue behind it without making the film too weak to pull off in larger pieces.
X2
The Rep. that replaced mine used a steam gun, heating it and pulling it horizontally to the side vs. 90 degrees from the surface. He removed it in big sheets. When pulling it stretches and lifts from the surface. Seems like it took him between 1-2 hours, but that was 5 years ago and I don't recall the exact time.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
Shot-N-Az
fuzzyface wrote:
The wallpaper steamer is working, the******still comes off in small pieces, but instead of dime size, they are now dollar bill size. This is going to be a tedious multi-day project.
From what I have read on here and other places, that is progress!
jurzbill
Diamond shield wanted $400.00 to take if off mine. This would be the third time if I take it off. They knew there was a problem with this stuff yet they continued to put it on. Full cost I was given to remove and put back on this time, over $1,000.00.
I blame the rv companies for allowing this stuff put on their rigs. DS now saying they have a better product. Wonder how many will be sucked into that one?
2004 ksdp 39ft
toad:2014 Ford CMax
:W
FMCA F359471, Newmar Kountry Klub 17645
bill, linda cary grant, carley.
chance and chase are with us in spirit and travels with us where ever we go.
Greyghost
Send a PM to CloudDancer. He removed the DS off of his DS a few years ago.
Pat & Roger Fisher
2005 American Tradition 40W
2012 Honda CRV EX-L 2WD,
Jewel, Clifford and Thor - Bouvier Des Flandres
fuzzyface
fuzzyface
I'm going to Lowes to purchase a steamer this morning -- will update on the results.
