โDec-11-2017 06:17 AM
โDec-12-2017 02:25 AM
SidecarFlip wrote:down home wrote:
I use the CAT brand biocide additive when I can get it.
I use another brand, that I don't remember the name of from a local diesel shop.
They are both about 32-39.00 bottle of 32 oz. One oz per ten gallons, I think but don't quote me.
It is a terrific idea, today, when there is no sulfur, to amount to anything in diesel. If you use BioDiesel it is absolutely a necessity. Basically cooking oil the microbes really like it with a bit of moisture or not.
Power Service etc I cannot see anything in the ingredients about any real biocide in it. I look anytime we stop for a bit for what they have on the shelves of Loves, or Fyin J etc. Nothing worth my money.
EPA doesn't want us using it.
Power Service diesel additive is a Cetane improver only. If it was a biocide or contained any chemical lethal to microbes in fuel, it would have to be labelled as such and it's not.
I have used the CAT biocide before but it's hard to get whereas the Power Kleen is readily available.
I also use the CAT fuel additive when I can find it. It's hard to find as well.
One look on the back label tells you right away if it is indeed a biocide. It will have all sorts of warnings about disposal of the empty container, inhalation hazards and all that stuff the government requires,,,
โDec-12-2017 02:13 AM
โDec-11-2017 06:56 PM
โDec-11-2017 06:03 PM
โDec-11-2017 05:41 PM
jplante4 wrote:wvabeer wrote:
You have me talked into it. Mine was filled up at the end of October, batteries removed and covered. I'll add some biocide tomorrow.
You'll need to figure out a way to agitate it. I add my winter products at the last fillup and it's a 6 mile drive to storage.
โDec-11-2017 04:05 PM
โDec-11-2017 03:14 PM
SidecarFlip wrote:jplante4 wrote:
I put a bottle of Power Service injector cleaner in about every other tankful and one into the last tank. You need to drive it for a while to get the stuff into the injectors. On that last fillup I also use Power Service anti-gel. Probably not needed on Cape Cod but it's cheap insurance. Wal*Mart carries this. They also have a biocide, but if you keep the tank full you shouldn't need it.
Power Service
Not always true. Been there and did that and it's not a cheap date (repairing and replacing components and flushing tanks because of algae growing in the fuel over the winter.
While I don't have a diesel pusher, I do have a diesel pickup truck that sits all winter in the garage, next to my truck camper, usually from November to April every year and a couple diesel farm tractors too. I lucked out on the tractors, didn't on the truck.
I got a case of algae (red slime) in the fuel system over the winter 3 winters ago. I didn't know it until I got the truck out and it died in the driveway, I went hmmmm, what's going on, so I did all the usual checks (both fuel tanks were full and I had Power Service anti-gell in both tanks (I have 2 on the truck) so I pulled the fuel filter (my filter sits on a cast aluminum bowl atop the engine.
When I pulled the filter it was a solid mass of red, slimy gook and it stunk. So, I had to remove the fuel bowl (no easy job and clean it plus it ate the lift pump so I had to replace that and I had to pull all the injectors and have them cleaned and benched because the goo was in the injectors too. All in all, I had about a grand in parts with me doing the wrench part. If I had, had a shop do it, I imagine it would have been at least twice that because pulling the injectors on a Powerstroke is a job in itself. Besides the mechanical stuff, I had to drop both fuel tanks, remove the sending units and pickups and have them steam cleaned inside and I replaced both sending units and pickups because they too were loaded with the goo......and all new duel lines too..
Just glad I have the tools and the know how to do it myself...
Moral of the story is this:
Straight diesel with no biocide added, you might get lucky and never have an issue but, if you do, it's going to be a costly one for you.
Biocide is cheap and it don't take a lot. I Power Service Bio-Kleen myself....and a dash of Power Service anti gel too.
That is my story and I'm sticking to it....:B
Additionally, because I have a Powerstroke I also use Archoil Friction / Stiction modifier and their fuel additive (which has biocide in it) as well. I picked up a real world 1 mpg in fuel mileage overall and the motor runs much quieter.
While neither here nor there concerning algae, I figured I'd toss it in too, while I was entering this post.
Have fun.
โDec-11-2017 03:04 PM
โDec-11-2017 11:58 AM
Power Service
โDec-11-2017 11:43 AM
โDec-11-2017 11:41 AM
โDec-11-2017 11:07 AM
โDec-11-2017 10:09 AM
โDec-11-2017 09:35 AM
โDec-11-2017 08:50 AM
